Old 22-10-10, 09:32 AM   #1
Geodude
Geodude's Avatar
Default Changing springs without removing forks?
Just wondered if it was possible to change front fork springs and oil on a 99 sv650 naked with forks in situ?
Old 22-10-10, 09:42 AM   #2
punyXpress
punyXpress's Avatar
Default Re: Changing springs without removing forks?
Possible, but not really advisable.
The oil in your forks MAY be 11 years old and will smell bad enough for a skunk to stick its head out the window.
If you can get the front wheel out ( watch for the speedo driver ) the next step of removing the fork legs is usually easier. Just remember to loosen the fork caps a little before undoing other bolts. Try to flush as much carp out as possible & then just take your time getting the air gap right. If you weigh more than 8 stone, you would also benefit from heavier springs. Reassembly is reverse of what you've just done - best of luck!
Now: Street Triple R
Old 22-10-10, 09:44 AM   #3
Dicky Ticker
Yes
Old 22-10-10, 09:49 AM   #4
simesb
I haven't done it, but others have said it is possible.
FWIW, I'd rather do the job properly and drop the forks out. It's not that difficult if you can support the front of the bike and you can drain the forks completely.
Old 22-10-10, 10:40 AM   #5
Geodude
Geodude's Avatar
As far as i know its never been done so its like riding a marshmallow! Thanks for the smell warning. How would i flush out all the carp?
Originally Posted by Dicky Ticker View Post
Yes
Proper job would be what i would like to do but have low spannering experience so dont want to make it worse and snap/bust stuff.
Old 22-10-10, 10:42 AM   #6
barwel1992
the hardest part is getting the fork caps off, thats how easy the job is.
Old 22-10-10, 10:43 AM   #7
Geodude
Geodude's Avatar
Really that easy, nice one cheers Dan
Old 22-10-10, 10:47 AM   #8
IMO do it right and remove forks
Old 22-10-10, 10:47 AM   #9
Luckypants
Luckypants's Avatar
After draining the old oil, put in some fresh oil, pump the forks a few times to force the oil through the damper rods etc, pour off oil which now has a lot of crap in it. If it's bad, then use paraffin instead of fresh oil as that will dissolve more crap, but make sure it's all out before filling with new fork oil.
Old 22-10-10, 10:53 AM   #10
Geodude
Geodude's Avatar
If you the all knowing yc say do it right then i will have a good try
Cheers for the info mate.
Front end -changing springs james160987 SV Talk, Tuning & Tweaking 23 28-04-10 05:26 PM
changing 2001 sv650 forks lennon38 SV Talk, Tuning & Tweaking 2 01-08-09 05:30 PM
Changing fork Springs and Butter bolts ejohnh SV Talk, Tuning & Tweaking 8 06-07-07 10:21 PM
Changing my fork springs ejohnh SV Talk, Tuning & Tweaking 15 04-07-07 01:41 PM
Changing fork oil in cartridge forks? jambo Bikes - Talk & Issues 13 24-06-05 07:32 AM
