Over the weekend, I found that I could turn the ignition key to the lock position and remove it and the bike kept running. I ended up using the kill switch and disconnecting the battery to protect the coils from overheating.
Before removing the ignition switch tonight, I decided to try it, and it worked perfectly. I'm a bit baffled as to the cause as the ignition lock barrel should have a permanent connection to the ignition switch. Anybody got any ideas? My worry now is that at some point when I'm out, the opposite will occur and I won't be able to turn the ignition on. |
Damp in the switch? Doesn't sound good though.
A good squirt of WD40 directly into the switch would probably eliminate the dampness theory
Check the switch is still fixed to the back of the lock barrel correctly.
Satnav for iPhone (Turn by Turn) | Owenski | Idle Banter | 28 | 30-06-10 02:55 PM |
Sticky key, difficult to turn in ignition barrel | Maverick9999 | SV Talk, Tuning & Tweaking | 9 | 05-03-10 11:56 AM |
Turn it off | BanannaMan | Idle Banter | 34 | 28-07-09 08:10 PM |
U turn | Ed | Idle Banter | 36 | 13-07-09 05:17 PM |
SV650 Ignition wont turn to lock after wreck | AFASTZ28 | SV Talk, Tuning & Tweaking | 6 | 30-08-05 06:37 PM |
