Im searching for a couple of these. They are a small bit which the indicator stem goes through on the back of the fairing and the rear gaurd before the fastening nut goes on. Pointy model
Can anyone assist please Last edited by ashtons99; 08-12-10 at 12:10 AM. |
Hi, no, they are the original factory fittings. They are like a small triangular flat plate with a locating lug. The threaded indicator stem goes through the hole in the fairing/mudgaurd then this little bit goes on the back followed by the fastener nut.
I appreciate your reply though |
Might help if you say which model of SV650 you have.
fairing brackets | stamasman | Stuff Wanted | 2 | 28-07-10 04:09 PM |
53mm dia light brackets for USD forks | barwel1992 | SV Talk, Tuning & Tweaking | 10 | 29-04-10 06:04 PM |
Any Mini-twiners wanting rid of pointy fairing lowers? | rowdy | Mini-Twins | 0 | 08-12-09 09:40 PM |
Race Fairing Brackets? | 66wilson | SV Talk, Tuning & Tweaking | 6 | 11-06-08 09:54 AM |
k2 lower fairing brackets | erics02 | Stuff Wanted | 3 | 11-11-07 12:56 AM |
