Hi there,
So the place where I have moved means that I have to leave the bike out in the cold albeit under a bike cover, this combined with long runs on the motorway may have caused the common fault with the speedo reading either 0 or giving erratic figures (although thankfully below the speed I am travelling I believe). It seems it only happens when I turn around hard right hand corners, and it's only sometimes. Seems to rectify itself when I turn the yoke to the left... Obviously somethings a little wrong with the speedo and I was hoping to fix it myself over xmas. The haynes manual seems to show how to replace the sensor but it seems to involve removing the front wheel. I have a front paddock stand but I am a little nervous working on the wheel, incase I don't tighten it enough and it falls off ![]() Any other advice to remedy it? I have read that wiggling the cable sometimes help, or using a space to stop the clamp from crimping the cable... |
Sounds more like a wiring fault to me. Check the cable from the speedo drive first.
I was hoping it wasn't that as it's more of a pain to replace than the sensor I heard...
Pointy Speedo Sensor - K8 | Nobbylad | For Sale - SV's and SV related items | 15 | 05-03-11 06:42 AM |
Pointy clocks/speedo | teddee | Stuff Wanted | 10 | 15-02-10 12:55 PM |
Pointy Speedo Change To KPH | Lissa | SV Talk, Tuning & Tweaking | 2 | 14-06-08 03:46 PM |
Pointy Speedo Technician Req. | STRAMASHER | SV Talk, Tuning & Tweaking | 3 | 13-09-07 07:10 AM |
Speedo wheel (Pointy) | fullstop102 | Stuff Wanted | 1 | 27-03-07 05:16 PM |
