Old 16-12-10, 09:02 PM   #1
Dfraser76
Default Is it possible to repair cracked fairing?
At the bottom of fairing where it is bolted to the bike i have a crack of about 2-3cm not caused by me but previous owner!
It is not that noticeable unless looked at closely but was wondering if it's possible to get this repaired?
Old 16-12-10, 09:09 PM   #2
SVforvictory
Default Re: Is it possible to repair cracked fairing?
This stuff seems pretty good: http://www.plastexexpress.co.uk/
Old 16-12-10, 09:14 PM   #3
leebex
I bought my lowers with one having 2 big cracks, I simply used a wide tipped soldering iron to seal the joint, then added in a strip of plastic and melted that in to bolster it up.
With some filling, sanding,filling and sanding it came out good.
Old 16-12-10, 09:20 PM   #4
I'd try and speak to your local motorcycle bodywork shop.
They will be able to make good job of it
Old 16-12-10, 09:27 PM   #5
BBadger
Soldering iron and more plastic to melt with some mesh metal to add behind the fairing and it will come up a treat with sanding.
practice 1st on somthing until youve got the nack though. took me a few tries but my vfr fairing is coming up a treat now and theres alot to do.
Old 16-12-10, 09:44 PM   #6
Dfraser76
Cheers for the advice now i know its possible might see how much i would get charged for a body shop to do it!
If it's too expensive might give a shot myself
Old 17-12-10, 10:51 AM   #7
Nobbylad
Nobbylad's Avatar
Depending on how bad it is, I reckon £50-£100. I had my fairing repaired by a local guy. It was smashed to pieces and I'd already got another off ebay when he said he could fix it. True to his word, he did a great job...so now I have a spare
Old 17-12-10, 11:38 AM   #8
Top tip if doing a 'fine crack' yourself. Get some apoxy resin and a pin or needle. Apply into the crack in a thin amount, and hold til set. This way you can secure it in the right place before going into plastic padding the back of the fairing.
It works, cause I haz done it
cracked fairing (REPAIR OR REPLACE) kurtis.randle Bikes - Talk & Issues 10 24-03-09 08:09 PM
How to repair cracked fairing? TheStudent Bikes - Talk & Issues 11 24-11-07 02:11 PM
Upper fairing cracked Tzindo SV Talk, Tuning & Tweaking 10 08-03-07 01:02 AM
fairing repair ? Warren Bikes - Talk & Issues 5 05-02-06 01:00 AM
Nose Cone fairing cracked SV650S_DUB SV Talk, Tuning & Tweaking 2 08-11-04 07:19 PM
