Old 30-12-10, 06:41 PM   #1
Rob969
Default Which brake line set up?
I'm about to buy a new set of brake lines but was wondering what the pro's and con's are between race style or OEM i can see the obvious one which is the race set up is cheaper (2 lines instead of 3) but is there any other considerations.
Thanks
Old 30-12-10, 07:00 PM   #2
Default Re: Brake line set up.
If you have the race set up, then you'll still have one brake line, if one should fail.
If the line from the MC went on the OEM set up before the splitter, you'd have no brakes
Old 30-12-10, 07:03 PM   #3
as mavi, like the race set-up for that reason and the extra pressure that the system has.
Rubber lines are better in winter as the braking force is less and reduces the risk of lock up (slightly- still no substitute for accidentally grabbing a handful!)
EDIT: SS's answer is correct.
Last edited by andrewsmith; 30-12-10 at 08:31 PM. Reason: Sid Squid provided right answer
Old 30-12-10, 07:17 PM   #4
Rob969
so no real downsides then. Probably order myself a set a race style then seen as though there cheaper
Old 30-12-10, 07:24 PM   #5
look at Goodridge, Hel or Venhills websites as they sometimes was winter deals on the lines
Old 30-12-10, 07:40 PM   #6
Rob969
Default Re: Which brake line set up?
cheapest i've seen is venhill for about £45 and the other 2 for around £50
Old 30-12-10, 07:48 PM   #7
Biker Biggles
Biker Biggles's Avatar
Is that right?At the MC both lines share a banjo bolt,and pressure goes equally through both lines.Surely if one line fails pressure is lost throughout the whole system?
Old 30-12-10, 08:26 PM   #8
AndyBrad
thats what i thought.
race style will be easier to bleed and offer better brake feel. standard will look neater
Old 30-12-10, 08:27 PM   #9
Completely wrong!
Correct.
There is no functional benefit to either way, but a two line system is cheaper - the unions are by far the more expensive of the parts of the lines. A two line system simply has only four unions instead of the six that a three line system has.
If you want to do it the neatest way then take one hose from the master cylinder to the right caliper, then one from there over the mudgaurd to the the left caliper - sightly shorter overall line length.
Old 30-12-10, 08:30 PM   #10
Completely wrong!
Correct.
Stand corrected by SS
rounded nut on brake line. doser SV Talk, Tuning & Tweaking 11 15-12-10 03:45 AM
7mm brake line hardhat_harry SV Talk, Tuning & Tweaking 7 09-03-10 10:18 PM
HEL Braided brake line help DoubleD SV Talk, Tuning & Tweaking 9 07-03-08 06:56 PM
Brake Line Clips, really need them. DoubleD Stuff Wanted 14 05-03-08 05:52 AM
Which HEL brake line set? thedonal SV Talk, Tuning & Tweaking 23 09-01-08 10:03 AM
