Mini-Twins Goto Minitwins Official Site
Old 31-12-10, 08:51 AM   #1
jacknell
Default k6 minitwin prep question.
Is it necessary to remove the electric radiator fan ,is there any advantages. If i remove it what about the tempreture sender that is wired into the fan.
Where can i buy a race wiring harness.
Before i forget what lenght 520 chain do i need to run 14f and 46 rear sprockets.
Old 31-12-10, 09:14 AM   #2
Berlin
Default Re: k6 minitwin prep question.
Removing the fan saves weight.
The Temp switch can be left in place, without wires.
You can also get rid of the thermostat to increase flow. but you need the temp sensor in the thermostat housing.
I'm not sure there is much you can do with the std harness. Once you've removed the lights and indies etc and their wires, there's not a lot else you can take off. So many sensors
Std length chain works fine.
Old 01-01-11, 07:10 PM   #3
coxxy
Consider different ratios Jack: 15:44 - 46 will see you good for all uk circuits, have broken lap records at three different circuits on these sizes
Old 02-01-11, 09:35 AM   #4
jacknell
Main tracks i will be at is, knockhill, East fortune, croft, cadwell. I believe most guys are running 14/46 for the shorter tracks. What you sugest for the longer tracks , croft cadwell.
Old 02-01-11, 11:25 AM   #5
coxxy
Cadwell we would go to 15:45
Old 02-01-11, 08:07 PM   #6
It think East Fortune is 15:45/ 46.
Its a fast'ish track (mini twin average speeds is 80 mph+) with 2 low gear hairpins.
Old 02-01-11, 08:20 PM   #7
TC252
Hi there,
last season I ran 15:45 and 15:46 at EF and the 15:45 is a better set up for a standard SV.
TC252
Paint Prep DarrenSV650S Bikes - Talk & Issues 5 21-06-10 05:46 PM
2001 SV650S trackday prep; I'm loose on turns, should I go Gixxer suspension or emulators? F16Falcon SV Talk, Tuning & Tweaking 6 29-07-09 10:14 PM
MOT tommoz so 7 hours prep.. Quiff Wichard Idle Banter 7 15-05-06 02:03 PM
didn't prep bike before winter nos Bikes - Talk & Issues 12 09-02-06 09:28 PM
Prep the bike for Winter Chipstix SV Talk, Tuning & Tweaking 27 12-09-05 10:23 AM
