Old 09-01-11, 09:51 PM   #1
sv650nutter149
Default Wheel bearing failure!
hi all,
just been going along when suddenly my rear wheel has started to clonk.... apon checking the rear wheel for movement it moves bout 5mm side to side....surely this has to be bearing right??? if so wheres the best place to get them from??
do you also suggest i do the front bearings as well???
cheers
ian
Old 10-01-11, 07:53 AM   #2
Spanner Man
Default Re: Wheel bearing failure!
Morning Mr Handles.
It's most likely to be the bearings at fault, & you can get them from.......Me you fool . Is the problem on the Zed, or the GSXR?
It would be worth checking the fronts as well whilst one is there.
Cheers.
Spanner Man
Old 10-01-11, 08:36 AM   #3
sv650nutter149
Haha stew tried calling u will try again in a min after I've taken patient to theatres
Replacement wheel bearing tolerance. lawson17 SV Talk, Tuning & Tweaking 2 16-01-10 08:22 PM
wheel bearing covers barwel1992 SV Talk, Tuning & Tweaking 6 05-11-09 10:05 PM
650 k3 wheel bearing numbers shiver85 SV Talk, Tuning & Tweaking 4 01-10-09 07:24 PM
Front wheel bearing shot? DanAbnormal Bikes - Talk & Issues 4 18-05-08 10:01 PM
Rear Wheel Bearing Removal TSM SV Talk, Tuning & Tweaking 10 20-03-06 10:54 AM
