Old 07-01-11, 11:41 AM   #1
bigchris
Default Bike running rough!
Bike ran like a pig this morning, was trying to cut out at idle after 20 mins riding, i could smell petrol and bike was backfiring a lot? Opening the throttle quickley, the bike just cuts out but roll it on smoothly it picks up?serviced the bike at the begining of week and it was running great, ive added carb balance lines and balanced carbs ( blocked the ends of afterwards ) and recentley greased up the carb plungers. I also checked airbox and connections for leaks but found nothing!
Can anyone help? Bike is doing my head in!!!! >:-/
Old 07-01-11, 12:03 PM   #2
mickhew
Default Re: Help! Bike running rough!
Sounds like it's only running on one cylinder, you can smell unburned petrol. I would start off by changing the spark plugs. Or check and clean first. When you say you serviced it, did you fit new plugs? if so, unlikely that one has failed already, if you kept the old ones you can fit them back in to test. Sometimes plugs work, then fail as they get hot.
Old 07-01-11, 12:13 PM   #3
Both HT leads seated properly? Front plug damp? Choke cables not stuck when you put them back in (seated properly in nipple)?
Old 07-01-11, 01:55 PM   #4
B1k3R
What YC says.
Is it chokie (lumpy) or just like firing on one cylinder? I would check the plungers, plugs or leads have not come loose.
Could be rain affected. My SV was doing this in, what I thought, was not too much rain. Lucky I serviced the bike a few days after and fitted a fenda extenda also. I made sure that the front plug lead had a good coating of 3 in 1 silicone to stop any damp getting between the rocker cover, lead and plug top. Rode the bike on Tuesday through rain, sleet and snow and not a problem.
Old 07-01-11, 02:20 PM   #5
toxic
my guess is carb icing, have you any additive in the fuel?
Old 07-01-11, 02:22 PM   #6
bigchris
I did change the plugs for new uns, i set the gap to 0.08 like an idiot ( i know its 0.7 - 0.8 now ) and the bike ran like **** so i had em out and adjusted them to 0.8 and it ran a lot better until now. Maybe running the plugs at 0.08 has buggered them up?
Old 07-01-11, 02:23 PM   #7
bigchris
No i did move the heater sensor a bit nearer the frame though? It was inbetween the carbs?
Old 07-01-11, 02:25 PM   #8
toxic
the carb heaters aren't that effective, try a fuel additive like wynn's dry fuel or silkolene pro fst.
Old 07-01-11, 02:26 PM   #9
bigchris
Had the bike running at dinner break and its now revving high and low ( nearly stalling ) at idle?
Cheers for all your advice, i will check everything suggested later after work :-/
Old 07-01-11, 04:54 PM   #10
Default Re: Bike running rough!
Have a look at the idle adjuster, you may have nocked it.
I'm with YC sounds like something is loose or wet.
What states the battery in? Mine did v strange things before it waved the white flag and died
Running rough when hot svdemon SV Talk, Tuning & Tweaking 3 13-08-08 07:44 PM
Running rough, running out of ideas. Sarj SV Talk, Tuning & Tweaking 17 04-12-07 06:45 PM
Running Rough? mike_b SV Talk, Tuning & Tweaking 3 20-12-06 11:38 PM
Bike running rough at low speeds Grinch SV Talk, Tuning & Tweaking 11 24-11-06 09:20 PM
