Old 14-01-11, 12:13 PM   #1
DavieSV
DavieSV's Avatar
Default Attaching Fender Extender to Carbon Fibre mudguard?
Any one done it?
How?
I don't really want to drill it, I have never drilled carbon fibre & don't know if it will crack.
But can you glue to it without affecting the Carbon fibre and will it peel away at the weave?
DavieSV is offline   Reply With Quote
Old 14-01-11, 12:19 PM   #2
Default Re: Attaching Fender Extender to Carbon Fibre mudguard
Used clear silcon sealant on mine, sticks anything to everything pretty much.
It won't affect the carbon fibre either
Take the mudguard off, stick the feder extender on, clamp it in place, remove excess silcon with a wet finger to get a perfect finish, remove clamps once silcon has set.
Just be careful how and what you clamp it with, you could just use masking tape
Old 14-01-11, 12:25 PM   #3
DavieSV
DavieSV's Avatar
I was considering silicon but didn't know how well it would hold up over time with the vibrations & crud.
I used glass fibre resin on the SV front mudguard, but it made it very stiff.
Old 14-01-11, 12:39 PM   #4
No problems here, once its stuck its stuck. Ever tried removing old silcon?
Better still, its got flex in it.
Did the first with Araldite, sticks well, but messy and hard to get any residue off
Silicon gives a lovely clean finish, so long as you wipe any big lumps off
Old 14-01-11, 02:34 PM   #5
Araldite is a chew on!
Done mine last weekend took 30 mins to do it and clamp properly
Moegrips are the best thing to hold it with while it cures
Old 14-01-11, 03:39 PM   #6
barwel1992
drilling carbon is fine, so very easy to drill through, never cracked when i did it
Old 14-01-11, 05:31 PM   #7
Mole grips are a bit harsh, I'd used the little clamps with plastic jaws
Old 14-01-11, 05:51 PM   #8
20 mins effing and blinding with G clamps resulted in the mole grips with rags in the jaws
Old 14-01-11, 06:07 PM   #9
munkygunn182
munkygunn182's Avatar
Is that a yay or a nay for araldite? Got lots of araldite sitting doing nothing + 1 fender extender to fit!
2014 Triumph Explorer
1997 Honda VTR1000 - project bike - now working!
munkygunn182 is offline   Reply With Quote
Old 14-01-11, 06:18 PM   #10
daveangel
daveangel's Avatar
I used the belt and braces approach, some sealant to stop road dirt and water getting between the extender and mudguard, and as my curvy is yellow, four yellow plastic number plate bolts to attach it with some superglue on the bolt threads so they would never come undone and they wouldn't crack or deform the guard.
'carried away by a Moonlight Shadow. . . '
OOII SHIRLEY!!
'99 'curvy' SV650S, R&G Bobbins, Renegade Endcan, no anodised bling. .
daveangel is offline   Reply With Quote
Front Mudguard Extender? Mej Bikes - Talk & Issues 10 30-04-09 11:39 AM
mud guard extender / fender extender to fit K4 650s Chuky Stuff Wanted 5 26-10-08 11:58 PM
Curvey carbon fibre front mudguard fastdruid For Sale - SV's and SV related items 1 27-04-08 12:22 PM
Carbon Fibre front fender for a curvey dirtydog For Sale - SV's and SV related items 4 02-11-07 08:38 AM
Fender Extender? MitchC SV Talk, Tuning & Tweaking 8 06-12-04 12:11 PM
