Old 17-01-11, 05:54 PM   #1
hardhat_harry
Default Pointy R/H engine case fit Curvy?
Can you fit a pointy rh engine case and clutch cover on a curvy?
Fed up of the one on my track bike dripping
Old 17-01-11, 06:32 PM   #2
Spikenipple
Spikenipple's Avatar
Default Re: Clutch cover
I don't know if the designs are the same, but why don't you stick it on a lapping table and give it a good once over? Reassemble with a new gasket and a bit of hylomar, job's a goodun!
Had: K7 SV650S in Candy Sonoma Red
Now: MT-09
My old SV
South & West Surfer
Spikenipple is offline   Reply With Quote
Old 17-01-11, 07:41 PM   #3
hardhat_harry
Default Re: Pointy R/H engine case fit Curvy?
Whats a lapping table?
Tried new gasket, tried the best sealent money can buy (well £30 a tube).
Old 17-01-11, 08:26 PM   #4
Spikenipple
Basically a uniformly flat surface. Get a sheet of very fine sandpaper that's big enough for the whole cover to sit on, stick it on a glass coffee table (cause they're usually nice and flat) and rub the mating surface of the cover over the sandpaper in a figure of 8 motion. If you put some permanent marker on the cover before doing this, you'll see the high-spots where it's not flat, which will probably be where it's leaking.
Now: MT-09
My old SV
South & West Surfer
Old 17-01-11, 11:31 PM   #5
Well it will probably be leaking from the low spots... but yeah
Old 17-01-11, 11:33 PM   #6
Spikenipple
Well yeah, you know what I meant though ^_^
Now: MT-09
My old SV
South & West Surfer
Old 17-01-11, 11:36 PM   #7
hardhat_harry
Got pointy cams to put in it so I'll do it then.
Old 18-01-11, 01:47 AM   #8
zadar
Yes, all same except oil window location. Your oil level should be above F line with pointy cover.
Engine case paint? beabert SV Talk, Tuning & Tweaking 10 14-01-10 05:51 PM
Changing an engine case? Rich Bikes - Talk & Issues 5 02-09-09 08:23 PM
can a pointy engine go in curvy sottondan SV Talk, Tuning & Tweaking 2 05-07-08 08:42 AM
Curvy engine in a pointy rowdy SV Talk, Tuning & Tweaking 3 07-06-08 03:59 PM
snapped engine case bolt ben650 SV Talk, Tuning & Tweaking 15 21-11-05 07:59 PM
