Old 18-01-11, 08:45 PM   #1
muzikill
muzikill's Avatar
Default Rotor Puller needed Sv650s K3
Looking for one of these! - if anyone knows the best/cheapest place to get one its appreciated, i dont want to muck about fabricating or using tools not fit for the job - ive got a couple of weeks until i really need it so i can wait for delivery if it needs to come from afar!
Old 18-01-11, 10:56 PM   #2
Default Re: Rotor Puller needed Sv650s K3
Do not buy anything fancy it is an M20 fine pitch bolt
Old 19-01-11, 01:36 PM   #3
muzikill
muzikill's Avatar
Cheers dude . . Im sure someones posted the sizes and length on the forum, if i find a source for cheap ones ill put the info up for all. . .
Old 19-01-11, 05:02 PM   #4
Length does not matter TBH. I got one for a quid from local nut and bolt place. M20x1 IIRC (will measure), needs to be about 50mm long but not critical.
Rotor puller for curvy charlie13 Stuff Wanted 0 02-06-10 11:46 AM
rotor puller svryanpompy Stuff Wanted 17 17-03-07 07:48 AM
I need a rotor puller tool svrash SV Talk, Tuning & Tweaking 8 22-03-06 03:58 PM
Who's got my rotor puller? northwind SV Talk, Tuning & Tweaking 4 03-01-06 03:58 PM
Rotor Puller Tool TSM SV Talk, Tuning & Tweaking 6 07-12-05 06:24 PM
