Old 22-01-11, 03:18 PM   #1
sauluk
Default Bonding polypropylene?
Seems a lot of bits on bikes are made out of polypropylene (PP) which is, I've read, a difficult plastic to bond as it is resistant to a lot of adhesives / solvents.
My question is whether Araldite will work? more specifically the slow cure precision one, not rapid set.
Old 22-01-11, 03:24 PM   #2
rictus01
rictus01's Avatar
Default Re: Bonding polypropylene
Hmmmmmm, I suppose it's worth a try, if it's all you've got, I generally use this stuff, in th crack and if needed plastic weld the back.
Cheers Mark.
Old 22-01-11, 03:28 PM   #3
sauluk
Thing is, if it's not going to work I'm not going to risk it. One of the headlight lugs has snapped so if it wont glue I have to order a whole headlight... at quite some expense...
Old 22-01-11, 03:41 PM   #4
rictus01
rictus01's Avatar
As said I use the two part stuff I linked to, that works most of the time, but if you'll have to order a new one, no harm trying is there ?
Old 22-01-11, 03:58 PM   #5
You can buy PP specific two part adhesive, when I used to use it in my last job I got it from rs components www.rswww.com.
Depends what you expect from glue, structual stuff I would buy as above, if it's just cosmetic stuff that wont be subject to any stress then araldite will be fine IMO .
Old 22-01-11, 04:17 PM   #6
sauluk
It holds the headlights in place so I'd say structural. I might just pick up some new ones to be on the safe side but have just tested some araldite on 2 pieces of PP and will let it go off overnight...
Old 22-01-11, 09:37 PM   #7
Plastic weld it
Old 23-01-11, 01:23 AM   #8
Sally
Default Re: Bonding polypropylene?
Have managed to do this on my old SV using industrial strength glue.
Old 23-01-11, 10:53 AM   #9
sauluk
Plastic weld it
I test ran another bit of PP with araldite, flexed it a bit this morning and it snapped, not strong enough.
I don't have a plastic welder and they look pricey, more expensive than just getting a new headlight.
Think I'll just bite the bullet and sell mine on eBay to someone with the gear to fix it.
Old 23-01-11, 01:46 PM   #10
£5 for a cheap soldering iron, less than a decent bottle of glue
headlight bonding glue removal? leebex SV Talk, Tuning & Tweaking 7 10-09-10 08:18 PM
Bonding with my bike charlie13 Idle Banter 7 03-06-08 11:07 AM
