Old 22-01-11, 07:44 PM   #1
g13unisol
Default Gsxr rear shock bolt - where from?
I am planning on fitting a gsrx 1000 k5 rear shock to my k9 pointy but cannot find the gsxr bolt in need to replace the bottom one from my shock. Anyone know where I can buy one. Any advise on other parts I might need.
Old 22-01-11, 08:12 PM   #2
Default Re: Gsxr rear shock bolt
Its item 19+20 on this pic have a lookski http://www.alpha-sports.com/suzuki_parts.htm
Part nos
19 09159-10058
NUT
2
20 09103-10143
BOLT, LOWER (10X55)
1
Old 22-01-11, 08:19 PM   #3
Nobbylad
Nobbylad's Avatar
But them here => http://www.robinsonsfoundry.co.uk/
Or your local bike shop/dealer
Old 22-01-11, 08:59 PM   #4
g13unisol
Why do I need a different bolt any way.
Old 22-01-11, 09:01 PM   #5
barwel1992
because the sv one is to short as the bolt on the sv bolts in to the shock and does not have a nut on the end
Old 22-01-11, 09:09 PM   #6
g13unisol
I am new to this and this job for me is massive but the diagram i have here shows a nut and bolt at the bottom of the shock or an i looking at this all wrong.
Old 22-01-11, 09:12 PM   #7
barwel1992
so it does, mines not like that, but the gsxr shock bottoms will be thicker so you will most likely need the other bolt
Old 22-01-11, 09:25 PM   #8
I have not seen an SV shock with a nut, they are threaded. Maybe new ones are different.
Old 22-01-11, 09:26 PM   #9
g13unisol
Just looked in haynes manual and it is as you say will have to look at bike. This scares me by the minute i don't have much luck when i comes to doing things myself.
Old 22-01-11, 09:34 PM   #10
barwel1992
how close are you to me ? cv22 7gw
Is there a rear shock u can bolt on with out too many mods for a K1 K2 650S Sv-Rat SV Talk, Tuning & Tweaking 16 24-06-10 09:04 PM
rear shock bolt GSXR pencil shavings SV Talk, Tuning & Tweaking 4 25-04-09 04:26 PM
K5 gsxr thou shock going onto k5 pointy - will I need the lower gsxr shock bolt? Paul the 6th SV Talk, Tuning & Tweaking 37 31-10-08 12:26 AM
rear shock nut and bolt for a diff shock drag Stuff Wanted 0 22-04-08 03:52 PM
nuts & bolt for GSXR shock chris SVK3 SV Talk, Tuning & Tweaking 1 12-01-05 10:51 PM
