Old 23-01-11, 12:51 PM   #1
mcgrimes
Default Bike Cutting Out
Hey guys, my bike has recently started to cut out. It first happened sometime last week, when i had to filter most of my way to Uni. I was using lots of clutch control, and as soon as i was pulling up at uni, my bike cut out, but started up fine again, so presumed human error.
After arriving home, it noticed it was struggling to keep revving. It Usually idles at around 1.4k, but it was struggling to break about 1000.
Started it up agin this morning, and initially it runs fine, but after warming up/or changing gear, it cuts out. Starting it again, it struggles, and i need to provide it with a bit of throttle to get it going again.
With regards to the changing gear, no my stand is not down before anyone asks.
Could fuel be struggling to get to my engine?
Any thoughts as to what it could be?
Old 23-01-11, 01:07 PM   #2
ImplodedHamster
Default Re: Bike Cutting Out
mine does this sometimes as well, so will keep an eye on this one
Old 23-01-11, 01:11 PM   #3
Spikenipple
Spikenipple's Avatar
Adjust the idle, if I recall correctly it's in one of the gaps in the frame on the left hand side. If that doesn't help, check the airbox and snorkel for anything blocking it and make sure you've got oil in the engine
Had: K7 SV650S in Candy Sonoma Red
Now: MT-09
My old SV
South & West Surfer
Spikenipple is offline   Reply With Quote
Old 23-01-11, 02:07 PM   #4
mcgrimes
Thanks Spikenipple!
Doesnt seem serious, runs fine other than when you let off the throttle i suppose lol.
Old 24-01-11, 01:59 PM   #5
Richrallye
Its happening to mine too, tried the garage but to avail. Anyone help???
Old 24-01-11, 02:20 PM   #6
do the headlights get considerably brighter when you rev the bike?
have you been riding in the rain a lot?
Old 24-01-11, 02:49 PM   #7
benji106
I would try just adjusting the idle first, mine was doing the same, idle was just set a bit low.
Old 24-01-11, 03:24 PM   #8
ImplodedHamster
Yes!
recently bought so i dont know about the rain...
Old 24-01-11, 03:53 PM   #9
Originally Posted by ImplodedHamster View Post
Yes!
if it coughs and splutters a lot then its more than likely your battery/regulator then. FI bikes need a good condition battery to function properly. if the battery is in good state then check your front cylinder for dampness.
there are loads of threads on the front plug getting wet. other things are coil connectors and damp wiring connectors.
Old 24-01-11, 04:03 PM   #10
ImplodedHamster
the battery is fine (according to my optimate) how can i check the regulator?
Bike cutting out. lawriejones1 SV Talk, Tuning & Tweaking 18 08-08-12 11:14 AM
Help Bike cutting out Paul1984 SV Talk, Tuning & Tweaking 4 26-08-10 03:05 PM
Bike cutting out. ljm2008 Bikes - Talk & Issues 5 22-12-08 05:16 PM
help bike keeps cutting out lancasterlad SV Talk, Tuning & Tweaking 19 27-09-07 04:53 PM
K5, Bike cutting out!!! quikstu SV Talk, Tuning & Tweaking 15 21-04-05 12:46 PM
