Old 23-01-11, 05:54 PM   #1
Terah
Default Oil Drain Plug - Thread Stripped
Have just drained the oil and the plug thread looks like it has been stripped.
Can I just get a replacement plug or is it likely the thread in the sump is damaged too? If so, is there a fix?
Old 23-01-11, 05:56 PM   #2
Default Re: Oil Drain Plug - Thread Stripped
Get it Helicoiled.
I know my old boss got his done by a traveling mechanic, so you might not have to get it to a dealer
Old 23-01-11, 06:04 PM   #3
it may just be me but that bolt looks like its already got the remains of a heli-coil stuck to it.
could you try and remove the excess material from the bolt to see if it really is a heli-coil.
if its the coil part of the process it might just be a case of inserting a new coil or going up a size on the sump plug if the thread is clean enough.
the problem with inserting heli-coils in the sump is that no matter how clean you get the area you will always get oil dripping from the hole which buggers up the bonding agent.
Old 23-01-11, 06:10 PM   #4
barwel1992
use a timecert if it is buggered
Old 23-01-11, 06:47 PM   #5
SVMAT
As already said helicoil or re-tap the beast. Its an inconvinience but not the end of the world
Old 23-01-11, 07:06 PM   #6
Terah
cleaned up and slightly better pics (only got a camera phone handy)
Old 23-01-11, 07:09 PM   #7
barwel1992
hmm looks strange :/
Old 23-01-11, 07:15 PM   #8
I'll find my old one and see if its the same
Old 23-01-11, 07:44 PM   #9
Looks like it may be stripped, looks weird have a look in your oil drain tray for shards on metal that may shed some light.
to echo what Bib said, my local dealer will only timecert sumps now, because of the issues with Heli-coils
Old 23-01-11, 07:52 PM   #10
Holdup
Looks more like its stretched to me
HELP PLEASE - Oil Drain Plug Thread Stripped cbay SV Talk, Tuning & Tweaking 53 11-10-10 08:23 PM
Problems with oil drain plug Grey Rider Bikes - Talk & Issues 8 19-04-10 04:32 PM
Sump plug and stripped casing thread. mysteryjimbo SV Talk, Tuning & Tweaking 11 12-06-05 12:17 PM
where is the coolant drain plug?? hall13uk SV Talk, Tuning & Tweaking 34 25-05-05 04:25 PM
Oil drain plug- Help. Peter Henry SV Talk, Tuning & Tweaking 7 17-10-04 01:26 PM
