Old 27-01-11, 11:23 PM   #1
arcdef
Exclamation Curvy Starter motor
As above need a starter , must be in good condition and able to unscrew the terminal nuts as this is cause of mine breaking.
Need as soon as possible.
Ash.
Old 27-01-11, 11:31 PM   #2
Default Re: Curvy Starter motor
You want to send me yours and see if it can be repaired?
Old 27-01-11, 11:39 PM   #3
arcdef
tbh i could probably repair it but none of the spanners i have are thin enough to get round the second nut.
Actually look at this, im not sure you can buy the insulating washers by themselves so im not sure.....
Old 27-01-11, 11:41 PM   #4
Don't think you can, just make them.
Old 28-01-11, 10:32 PM   #5
arcdef
Bump!
Old 29-01-11, 12:57 AM   #6
husky03
i'll be removing an engine tomorrow so will get back to you regarding the condition of the one i take off
h.
Old 29-01-11, 02:22 AM   #7
rictus01
rictus01's Avatar
as long as the armature is in good nick, the rest can be easily fixed, done about 15 of these myself, 3mm industrial rubber sheet for the washers and copper braid to replace the connection, the boly can be chopped off if it's totally fubar'd, but easy enough to lock the inside square block in place and use a spanner normally.
Cheers Mark.
Curvy starter motor parts? Electro SV Talk, Tuning & Tweaking 22 03-01-11 10:18 PM
Wanted curvy starter motor mouse8197 Stuff Wanted 3 30-05-10 06:51 PM
Starter Motor Grinch Stuff Wanted 0 02-04-08 10:24 PM
Curvy and blue SK1 ate my starter motor Tin Man SV Talk, Tuning & Tweaking 1 27-06-06 02:48 PM
For curvy: Starter motor, carbs. northwind Stuff Wanted 7 26-11-05 12:18 AM
