Old 01-02-11, 03:49 PM   #1
beabert
Default Original brake disc(s) with at least 4.2mm left.
Bike 1999 sv650
One of my discs has reached 3.90mm and the other is 4.20mm! That is what different types of pads do (last owner only changed one side)
MOT is coming up soon, he passed it at under 4mm last time, but might not this time.
Really dont have £200+ for brand new set, so im looking for a part worn non warped original disc with at least 4.2mm left on it.
The 4.2mm is the thickness of the inner section of disc, not the lip left from the pads not reaching the outer edges.
So i want either;
One original disc at least 4.2mm for around £25
A set of original discs with at least 4.2mm for around £50
Or another good set part worn but is good working order.
Prices are based on set i found on ebay at 4.3mm
Might try a set from an english engineering place at £150 a set if i cant find one.
Thank you.
Old 01-02-11, 04:57 PM   #2
staylor
Default Re: Original brake disc(s) with at least 4.2mm left.
Hi there
I have a set of Front disks taken from a 2005 K6 SV650 when I converted it to a racer, at least 4.2mm on inner section I will even throw in Bendix pads for £50. call 07712 633582 if you wnat to discuss.
Steve
Old 01-02-11, 05:49 PM   #3
beabert
The pointy discs have a different model number, so im guessing they wont fit?
Old 02-02-11, 11:26 AM   #4
punyXpress
punyXpress's Avatar
squirrel_hunter has some - see for sale
Now: Street Triple R
Old 02-02-11, 05:29 PM   #5
beabert
cheers all provisionally bought some.
Brake disc jack930 Stuff Wanted 2 13-10-09 10:00 AM
original suzuki curvy front brake lever husky03 Stuff Wanted 0 28-02-09 10:55 PM
Front Left Hand Disc Ratty46 Stuff Wanted 2 09-03-08 11:11 PM
pointy left side front disc Apophes Stuff Wanted 6 05-03-07 01:32 PM
Doh, expensive lesson (disc lok left on) timwilky Bikes - Talk & Issues 17 01-03-07 09:40 AM
