Old 03-02-11, 09:07 PM   #1
thedonal
Default Pinlok insert coming loose (XR-1100)
Hi all,
I'm on my second visor (got one changed after about 3 weeks of owning the lid).
It appears that the insert is not sticking to the visor as well and therefore starts misting up inside.
Is it something I'm doing?
I do remove the visor to put some Bob Heath anti-fog on the inside (it still mists some with the chin-skirt attached), but rarely actually remove the insert from the main visor. Was fine since early December?
Is it just the securing pins that are coming loose?
Anyone else had this?
Ta!
D
Old 03-02-11, 10:06 PM   #2
Default Re: Pinlok insert coming loose (XR-1100)
I've had it with my Xlite.
If you pop out the insert and turn one of the pins so the slightly fatter side is to the centre.
It should cure it.
Also make sure the pins haven't popped a little, as if they're like the Nolans/ xiltes they loosen over time
Old 03-02-11, 10:17 PM   #3
thedonal
Ah- I'll try that- I've already had a go at rotating them.
Ta!
Old 03-02-11, 10:20 PM   #4
took two pinlocks for me to twig it!
Old 04-02-11, 09:35 AM   #5
-Ralph-
Yep, I was having the same problem with mine so I RTFM'ed, then rotated the pins, problem solved.
Catherine Wheel Final Whos Coming and "Other Bits" Thread - PLEASE READ IF YOUR COMING :-) 454697819 Pennine Massive 61 12-10-08 10:09 AM
gear selector coming loose Ollie_07 SV Talk, Tuning & Tweaking 10 12-05-08 02:35 PM
