Old 06-02-11, 09:52 PM   #1
g13unisol
Default Front end decision - Advice needed (pointy)
I have fitted a k5 gsxr1000 rear shock to my 09 sport and want to do the front end. I don't want to do the gsxr front end thing as I want the bike to look as standard as I can. I thought just changing the springs would be ok but apparently not. Was looking at this MATRIS EMULATOR TYPE FORK KIT from PDQ is it too much and a waste of money or should i just get hyper pro springs and race tech emulators. I will be doing a lot of track days so need a setup to suit.
Old 06-02-11, 09:53 PM   #2
speedplay
Default Re: Front end decision - Advice needed (pointy)
Give yorkie chris a shout.
Old 06-02-11, 10:02 PM   #3
+1
Old 07-02-11, 03:57 PM   #4
johnnyrod
johnnyrod's Avatar
I don't know about the Matris emulators but the Racetech ones aren't bad at all, these plus a set of linear springs (right stiffness for your weight) and you're there, have used this setup for many track days and have no chicken strips on my front tyre.
Old 07-02-11, 04:40 PM   #5
yup i think YC is doing voodoo injections.
there is another option as to keeping it 'standard' looking and that is GSXR600 K1-3 as they are RWU but have cartridge internals. biggest problem is getting a decent priced front wheel form a GSXR. the rest is pretty cheep as most folk want USD.
Old 07-02-11, 04:45 PM   #6
Brettus
definitely a vote for YC, admittedly I did end up with the GSXR front end but he can cater to all needs and will give you a straight answer on what is "best" for your particular situation.
Old 07-02-11, 05:25 PM   #7
davepreston
have you concidered upgrading to the sv thou front end, same rightway up forks but far more ajustability, and iirc a straight swap in
Old 07-02-11, 05:51 PM   #8
g13unisol
Thou front end hmm? What size is the front wheel as I have a set of 650 wheels and tyres for track days.
Old 07-02-11, 05:52 PM   #9
the sv1000 runs 120/70 on the front
Old 07-02-11, 06:06 PM   #10
g13unisol
Just had a quick look around looks a bit hard for me and my limited tooling and space. I think internals but off topic how does a thou compare to a pointy sv650 handling.
Front sprocket pointy, socket size needed? muzikill SV Talk, Tuning & Tweaking 5 31-08-10 07:02 AM
Advice needed on fitting front springs pms jones SV Talk, Tuning & Tweaking 9 22-09-09 07:39 PM
Tow bar - advice needed Camel Idle Banter 6 15-07-08 07:05 AM
Advice needed please aarond SV Talk, Tuning & Tweaking 0 02-10-07 05:10 PM
Front brake probs, advice needed. Dirty Baz SV Talk, Tuning & Tweaking 14 21-03-05 04:18 PM
