Old 14-02-11, 09:06 PM   #1
muzikill
muzikill's Avatar
Default SV.org rear window sticker for the cage!
As it says! - plus i'm on the look out for any others!
Old 15-02-11, 09:47 PM   #2
cbay
cbay's Avatar
Default Re: SV.org rear window sticker for the cage!
what sort of decals you after.
Drop me an email or PM.
Old 16-02-11, 10:01 AM   #3
muzikill
muzikill's Avatar
http://forums.sv650.org/showthread.php?t=89244
the last one (number 3) would be cool!
oil window is white svandy SV Talk, Tuning & Tweaking 24 20-12-09 09:41 PM
clutch window? carsounds_dan SV Talk, Tuning & Tweaking 4 13-06-08 02:15 PM
Well that's next season already out the window Jelster Idle Banter 4 22-06-07 08:01 PM
Should I be sat at my desk by the window...? Fizzy Fish Idle Banter 11 05-02-07 01:36 PM
The art of Cage dumping (Embracing a Cage free life) Halonic The Essex Lounge 16 28-06-06 08:55 PM
