Old 18-02-11, 12:00 PM   #1
Reeder
Default Renthal Ultra Lows, benefits?
Is it really worth me getting them other than aesthetics & will I notice much of a change in position?
I have a naked 05 SV
Old 18-02-11, 12:05 PM   #2
barwel1992
Default Re: Renthal Ultra Lows
depends what you want i use the streetfighter bars with brace
Old 18-02-11, 12:06 PM   #3
Reeder
Well I want the bars to be lower without going for the ugly flats... Will it actually be noticably different or just quite subtle?
Old 18-02-11, 12:08 PM   #4
barwel1992
they will feel a lot wider, thats the main advantage height im not to sure but the wider the bar the wider apart your arms are so thus lowers your body position any way so it should be quite noticeable
Old 18-02-11, 12:09 PM   #5
Reeder
With bar end mirrors are they then going to be too wide to be practical?
Old 18-02-11, 12:17 PM   #6
barwel1992
hmm some times it can be a bit to wide but mine are really wide, i have only ever hit 2 mirrors with my mirrors the first was not my fault and the second was
this might give you an idea of the width
Old 18-02-11, 12:22 PM   #7
Reeder
I suppose generally I don't do much filtering so it shouldn't be a problem.
What made you want to go for the high bars?
Old 18-02-11, 12:29 PM   #8
barwel1992
well they came on the bike after i destroyed the first set i decided i liked them so went with them again but now i could't go any lower after what i have done to the bike
basically my bike sits nose heavy 35mm raise at the rear with a 25mm drop at the front and the k3 higher sub frame, so i already sit nose down **** up if the bars were lower i think id find it uncomfortable
Old 18-02-11, 12:35 PM   #9
hindle8907
hindle8907's Avatar
i got a set of black Ultra Lows for sale reeder, yes they feel much better than standard bars more natural position .
Old 18-02-11, 01:59 PM   #10
Reeder
But you'd probably sell them to someone else and forget I wanted some wouldnt you hindle!!!!
benefits kitkat Idle Banter 28 24-11-10 06:48 PM
2009 Highs and Lows. Lissa Idle Banter 29 30-12-09 01:17 PM
2008 lows and highs Shellywoozle Idle Banter 46 27-12-08 07:11 PM
NEC 2008 - the highs..and the lows.. in pictures! vzzzbuxt Bikes - Talk & Issues 9 08-12-08 10:33 PM
ultra seal? ben650 SV Talk, Tuning & Tweaking 9 20-03-07 11:49 PM
