Old 21-02-11, 08:29 AM   #1
daveyrach
Default New owner, service interval and maintenance questions.
Picked up my 'curvy' 1999 SV650S yesterday i have a few questions as i don't yet have a manual.
1. What are the service intervals and what need doing
2. Are there any known problems the SV could suffer from
3. Any idea what could cause the throttle to not self return?
What oil would people recommend and after market oil filters, do they cause a problem?
Just so you know it is dyno-jetted and has a K&N filter, don't think this should make any difference.
Cheers guys
Old 21-02-11, 04:57 PM   #2
mickhew
Default Re: New owner, service interval and maintenance questions.
If you want a workshop manual p.m me, I have a full workshop manual, tells you all you need to know. Aftermarket oil filters are generally fine. I use Putoline oil. Throttle cable itself might cause the throttle to stick, but could be the linkage on the carbs, might needs some WD40.
Old 21-02-11, 07:30 PM   #3
hongman
What is the history of the bike currently and what (if any) service history has it got?
The "big" one is every 15k miles where valve clearances need to be checked and adjusted if necessary.
Most popular complaints with the SV are probably reg/rec (whether correctly diagnosed or not...) and suspension. Oh and wet plug syndrome.
Throttle has 2 cables, check what condition they are in, as well as the carb linkage as mentioned.
If you are unsure of the service history and know how to wield a spanner, give it a service yourself. Will be a good chance to familiarise yourself and also spot any other potential issues!
Old 21-02-11, 08:11 PM   #4
Jordy
Hi mate, welcome to the forum.
PM me your email address and I'll send you the 99-02 service manual (PDF file) which includes a periodic maintenance chart.
And anyone else reading this who wants it, just drop me a PM.
Old 21-02-11, 08:20 PM   #5
daveyrach
Didn't come with service history, just 1 MOT and TAX, i'm very handy with a spanner intend to service it this weekend.
How does this sound to all, they are the mods it came with:
UPRATED FRONT FORK SPRINGS
GSXR K4 REAR SHOCK
Dyno Jet
K&N Air Filter
New clutch plates and heavy duty springs.
Wood craft bilet aluminium clutch cover
Front and rear braided hoses
Pair of Pirelli Diablo Rosso Corse fitted
Rear sets fitted
Carbon Can Co exhaust fitted
Old 21-02-11, 08:25 PM   #6
barwel1992
k4 gixer shock is way to short for the curvy
zx10r (not sure what year think 05) is good
Old 21-02-11, 08:28 PM   #7
daveyrach
Feels good handles well can't complain so far. What effect wold a short shock have?
Old 21-02-11, 08:34 PM   #8
barwel1992
slow turn in, you will almost have to fight the bike in to corners if you ride link a granddad then you wont notice but if your fast paced you will, i also belive the spring rate is lower than stock and thats not good as its to soft
im using a gsxr thou k4 on mine but i have a pointy that uses a different linkage.
Old 21-02-11, 08:37 PM   #9
daveyrach
Well i only really use it to commute thru town so don't get the opertunity to go fast often. Seems comfy tho
Old 21-02-11, 08:41 PM   #10
barwel1992
fair enough
ZX6R 2004 service interval? SUPERSTARDJ01 Bikes - Talk & Issues 0 24-10-09 02:01 PM
wheel bearing service interval? doser SV Talk, Tuning & Tweaking 11 27-08-09 09:32 AM
Service Interval jamesnolan SV Talk, Tuning & Tweaking 3 31-07-07 04:23 PM
3rd service interval mileage steveg SV Talk, Tuning & Tweaking 5 10-10-06 12:22 PM
Service Interval + 2005 model swordtail SV Talk, Tuning & Tweaking 4 31-03-05 07:17 AM
