Old 22-02-11, 09:31 PM   #1
cbay
cbay's Avatar
Default 2K Paint or Rattle Can?
Evening All!
I have decided I have a little paint job on my hands.
Do I either attempt to do a couple of fairings by Rattle Can (Sand, Prime, Paint, Lacquer)
OR
Buy an Air Compressor all the tools required and find a supplier of some 2K Paint?
What will be the difference in quality, could you tell that much?
Any suggestions or help will be ace!
Old 22-02-11, 11:27 PM   #2
beabert
Default Re: 2K Paint or Rattle Can....
Well you could always sell the stuff after if you think you wont use it again.
I found it very hard to get a good finish using a spray can. Ive done it for brackets and stanchions etc, but not whole fairings. I personally wouldn't use spray cans. Not that it can't be done with a lot of patience and attention detail.
Old 23-02-11, 01:31 PM   #3
philbut
Default Re: 2K Paint or Rattle Can?
If you are using 2K you WILL need some breathing gear. Don't spray without it, you will do some serious damage to your health!
generally rattle can jobs loom ok to begin with and then end up looking a bit poo. Technically you can achieve the same finish but it is harder. Important to ge tth temp and humidity right too.
Old 23-02-11, 01:58 PM   #4
read that
http://www.bayarearidersforum.com/fo...d.php?t=264901
Old 23-02-11, 02:09 PM   #5
cbay
cbay's Avatar
I'm reading... Might take me a little while.
Old 23-02-11, 02:16 PM   #6
timwilky
timwilky's Avatar
I always use 2k, but then again I have an air fed mask, compressor, gun.
And still I do a poo job as I don't spray enough to be competent.
Give the work to a pro to do, save an age fixing it and right first time
Not Grumpy, opinionated.
Old 03-03-11, 11:58 AM   #7
cbay
cbay's Avatar
So far so good! Results are looking better than I hoped!
Old 03-03-11, 12:00 PM   #8
philbut
which option did you go for? Any pictures? I need to respray a corner of my Fireblade nose cone, so would be interested to see the result.
Old 03-03-11, 12:01 PM   #9
Owenski
pics pics pics
Old 03-03-11, 12:03 PM   #10
cbay
cbay's Avatar
Rattle Can, I thought, I haven't got anything to loose except a few pounds and some prep time.
I'll upload some pics in a min but hard to see as fairing still currently hanging from ceiling in garage.
Top end rattle, if not cam chain, what else could it be? Taipan SV Talk, Tuning & Tweaking 8 23-06-10 09:17 AM
Camchain rattle. yorkie_chris SV Talk, Tuning & Tweaking 14 14-06-09 09:12 AM
New K8 rattle mustnt grumble SV Talk, Tuning & Tweaking 15 13-04-09 09:55 AM
What's this rattle northwind SV Talk, Tuning & Tweaking 10 07-05-08 06:42 PM
Rattle? barmy.biker SV Talk, Tuning & Tweaking 8 30-11-07 07:49 AM
