Old 27-02-11, 11:34 AM   #1
jimc
Default brake fluid leak advice please
I have just opened garage and there is a patch of brake fluid under front left hand brake caliper. what has happened and what do i replace? thanks for any advice.
Old 27-02-11, 12:49 PM   #2
hongman
Default Re: brake fluid leak advice please
If you can't spot the leak from a visual check/trace, I'd have the lot off and serviced.
Old 27-02-11, 01:01 PM   #3
toxic
caliper seal has probably leaked, new seal kit required.
Old 27-02-11, 01:01 PM   #4
Dave20046
Dave20046's Avatar
Hongman's above is probably the best advice (new copper crush washers all round)
Alternatively you could degrease and dry it all off and talc it up (or try without) and see if you can spot where it's leaking from.
Old 27-02-11, 03:09 PM   #5
tim8061
Sure it's not the fork seal leaking and running down the leg?
Brake Fluid Everywhere! mikebrooman SV Talk, Tuning & Tweaking 12 11-04-10 11:21 AM
Brake fluid - going up! 5150 SV Talk, Tuning & Tweaking 9 14-07-09 11:56 AM
Brake Bleed nipple/Mityvac/Brake Fluid query Ceri JC SV Talk, Tuning & Tweaking 15 20-01-09 02:04 PM
What Brake Fluid... DoubleD SV Talk, Tuning & Tweaking 10 03-03-08 11:21 AM
Brake fluid Trix SV Talk, Tuning & Tweaking 14 20-01-05 11:13 AM
