Old 01-03-11, 04:21 PM   #1
ThEGr33k
Default Are these dirty or normal? (valves)
Took the exhaust off last week and welded in some bigger Bungs for sensors for getting the bike Dyno'd. Thought id take a pic and see what the state of them was. Thing is im not sure, looks like a fair amount of build up to me but is that normal?
Taa
Old 01-03-11, 05:41 PM   #2
benji106
Default Re: Are these dirty or normal? (valves)
got a bigger picture?
Old 01-03-11, 06:19 PM   #3
embee
embee's Avatar
Doesn't look unreasonable to me. Depends what it's done really.
Old 01-03-11, 07:44 PM   #4
ThEGr33k
Coming upto 37k miles.
Is it something that will improve if the A/F is brought more inline? Or does it not matter?
Old 01-03-11, 08:36 PM   #5
Fade
They look normal for 37k Miles, is that oil at the top of the whitish build up?
You will get build up whatever the AFR, remember your burning stuff in those cylinders.
Old 01-03-11, 10:11 PM   #6
irons
need to put my glasses on to see that
Old 02-03-11, 12:26 PM   #7
ThEGr33k
It does look a little like that could be the case with oil, it looks a little erm, moist. I've never noticed any blue smoke or the oil level dropping at any silly rate. It might just be a tiny weep through the guides.
Cheers, for the info anyway. Im still learning
Old 02-03-11, 10:06 PM   #8
embee
embee's Avatar
Just for info, valve stem seals are metering devices, they pass a very small amount of oil down the guides for lubrication, they are not meant to be perfect seals. The angles of the lip (on top and underneath) are carefully designed to achieve the right metering, and will work reasonably consistently even with some wear of the seal and also with the range of pressure differentials across the lip.
A small hint of dampness is not unusual since there should be a trace of oil in the guide.
This one shows the angles at the top lip, and intersetingly it also has a "gas lip" below the top one which is there to stop high pressure gas blowing back up the guide in pressure charged engines. (SV seals won't have this feature).
Old 02-03-11, 10:42 PM   #9
ThEGr33k
Ah cool. Thanks for the info Embee! Something else I didnt know
Dirty Valves lukemillar Bikes - Talk & Issues 10 16-08-09 12:56 PM
dirty valves oldie SV Talk, Tuning & Tweaking 9 13-01-09 04:00 PM
valves Wideboy Bikes - Talk & Issues 19 12-10-08 11:56 AM
Dirty. Dirty.. Dirty... Bike!!!! Cam_73 SV Ecosse 7 17-03-07 11:42 PM
Dirty, Dirty Leathers ooer! muzikill SV Ecosse 3 16-03-07 12:19 PM
