Old 01-03-11, 06:28 PM   #1
irie
Default How do you correct the Rev Counter?
I've done searches but can't find any solutions.
The inj SV650 rev counter is hopelessly optimistic, does anyone know how it can be corrected to show a 'genuine' reading particularly higher up in the rev range?
Maybe the simplest way is to find out how much it's out on a dyno, take the instrument to pieces, and simply move the needle down a bit so that it's reasonably accurate between 8-10k???
Old 02-03-11, 05:08 AM   #2
sath182
Default Re: How do you correct the Rev Counter?
I know the speedo is 9% generous, but this is the first I've ever heard of the tach being inaccurate.
Old 02-03-11, 09:06 AM   #3
irie
Regularly shows over 11,000 rpm without hitting the rev limiter which is of course a fairy story (race bike, standard ECU).
Old 02-03-11, 09:47 AM   #4
tom-k6
what year is your bike?? ive heard a few slipped through around K3/K4 with either no rev limiter or a higher rev limiter.
Old 02-03-11, 10:02 AM   #5
Berlin
So technically thats a kit ECU and worth a fortune and NOT cheating under minitwin regs! Where can I get one? :P
Old 02-03-11, 04:43 PM   #6
hongman
I read similar somewhere, think Barwel mentioned it sometime in the past.
Someone will prob know how to check and confirm if this is the case.
Just not me
Old 02-03-11, 04:52 PM   #7
BBadger
Interesting as my sv (k4) will happily rev abit over 1k more into the red line before the limiter kicks in.
Old 02-03-11, 05:16 PM   #8
SV650Racer
Iries bike is as far removed from a minitwin that you can get on an SV LOL. Irie - you need a race dash!!
Old 02-03-11, 05:33 PM   #9
irie
It's a K9.
Old 02-03-11, 05:35 PM   #10
irie
Yeah I know I do but it won't make me go any faster!
Do i have the correct battery? andyfordceo SV Talk, Tuning & Tweaking 3 01-11-08 12:13 PM
is it correct oil? viva_unix SV Talk, Tuning & Tweaking 10 23-12-07 05:41 PM
Counter counter steering - does it exist? thor Bikes - Talk & Issues 30 22-10-07 11:17 AM
Is my licence correct??? neilhatch Bikes - Talk & Issues 4 25-03-07 09:08 PM
PSI gauges which one is correct ? SpankyHam Bikes - Talk & Issues 13 18-07-06 06:58 PM
