Old 09-03-11, 12:20 PM   #1
vardypeeps
Default Scottoiler SV650s K4
Afternoon guy's
I used to have a V system fitted to my old SV650 (99) and I managed to mount the RMV (Oil holder with adjuster) onto the back of the rear cylinder head.
It was weird as there was a perfect treaded hole for one of the brackets to just screw into.
Main question is does anyone have an ideal location for the RMV on a K4 pointy? Easy access, no drilling holes etc?
Cheers,
Rob
Old 09-03-11, 02:51 PM   #2
badsaboy
Default Re: Scottoiler SV650s K4
mine is under the pillion seat!
Old 09-03-11, 03:38 PM   #3
Luckypants
Luckypants's Avatar
Lozzo did a really neat install on his pointy. See the pics here http://forums.sv650.org/showpost.php...1&postcount=32
I fitted one under the pillion seat on a pointy, tucked down low under the bit between the rider seat and pillion seat on RHS. Not sure but there may be room to put it under the rear bodywork, mounted to the outside of the sub-frame. This could make filling and adjusting tricky, this was the reason I didn't bother.
Old 09-03-11, 06:00 PM   #4
warrenhewitt10
Mines under the pillion seat too
Old 11-03-11, 12:10 PM   #5
vardypeeps
Ended up popping it under the pillion seat. I've managed to wedge it inbetween the helmet holder/luggage hook on the right hand side and part of the subframe. It's almost vertical and nice and sturdy.
Vacuum pipe took the usual route under the hinge for the fuel tank and the oil feed pops out from behind the fairing secured to the back of the tool box/battery box then through the swing arm next to the shock.
Scottoiler Nobbylad For Sale - Other Bikes and General biking items 4 10-01-11 12:19 AM
Scottoiler Install 05 SV650S tayto94 SV Talk, Tuning & Tweaking 28 29-12-08 06:47 PM
scottoiler help hovis Bikes - Talk & Issues 3 29-09-08 04:41 PM
DIY Scottoiler Diveboy Bikes - Talk & Issues 1 11-03-06 08:51 PM
Air in my scottoiler iffy SV Talk, Tuning & Tweaking 2 16-03-05 03:42 PM
