Old 09-03-11, 08:11 PM   #1
Kenzie
Kenzie's Avatar
Default Is this Scotoiler fitted correctly?
Here is a snap of the K7 I'm getting at the weekend. Having no experience of Scotoilers, is this set right?
Old 09-03-11, 08:13 PM   #2
metalhead19
Default Re: Is this Scotoiler set correctly
Its not particularly discreet but if its in the correct position by the sprocket i see now reason for it not to work
Old 09-03-11, 08:18 PM   #3
Kenzie
Kenzie's Avatar
Sorry, missed the question mark off the end! I did think it looked abit weird, how could I improve it?
Old 09-03-11, 08:24 PM   #4
metalhead19
Instead of sending it along the top of the chain guard you could link it along the bottom/inside/top of the swing arm.
Old 09-03-11, 08:37 PM   #5
kaivalagi
Decent routing in the third pic here: http://forums.sv650.org/showpost.php...1&postcount=32
Mark
Triumph and Suzuki owner
Old 09-03-11, 08:51 PM   #6
Kenzie
Kenzie's Avatar
Would this be better? (red line) Down behind chainguard, along top of swing arm then down behind swing arm to sprocket? Is it in the right place to start with? Also, how can I fix it to the swing arm? Cable ties?
Old 09-03-11, 08:58 PM   #7
Looks to be flecking the tyre a bit or are those moulding marks?
Old 09-03-11, 08:59 PM   #8
kaivalagi
The pic I linked to above used the same bolts on the underside of the swinging arm by the looks of things, not looked so I'm not sure if it was drilled for the job or not...if it was then cable ties it is...atleast the swinging arm is black
Mark
Old 09-03-11, 09:07 PM   #9
Kenzie
Kenzie's Avatar
They are moulding bits, not sure how old the tyre is. I don't mind how it looks, it's just the ring terminal they have used on the chainguard screw. What would you guys advise? I could just paint that terminal black so it's not so obvious.
Old 09-03-11, 09:34 PM   #10
metalhead19
Scottoiler do stick on clips that attach to your swing arm and hold the tube in place. Thats what I currently use
HELP! Please. Clocks not working correctly. cbay SV Talk, Tuning & Tweaking 8 08-03-11 04:37 PM
Scotoiler Mr_Chin For Sale - Other Bikes and General biking items 3 12-02-11 08:41 AM
Crash.NET - Lorenzo airbag deployed correctly. NewsBot News 0 20-11-09 03:40 PM
gearbox not selecting gear correctly. DoubleD SV Talk, Tuning & Tweaking 5 30-08-06 02:22 PM
scotoiler cuffy Stuff Wanted 3 14-07-06 01:44 PM
