Old 14-03-11, 06:37 PM   #1
daveyrach
Default Curvy front master cylinder service?
How easy is the above to do? I have the kit and necessary tools just wondered how quick /easy it is and i take it i need to bleed the brakes.
Old 14-03-11, 06:46 PM   #2
Nicky S
Nicky S's Avatar
Default Re: Curvy front master cylinder service
well you dont have to bleed the brakes i just got a pipe clamp and clamped the lines just before they went into the master cyclinder then when you put it back on you just leave the lid off and pump the lever a few times and watch all the bubles come out.
lazy mans way lol
its not that hard to do at all only problem i had was getting the clip out (cant rember what they are called but that was a pain).
why are you doing the service may i ask ??
Curvy With Lots Of Bits ...
But Still More To Come
Nicky S is offline   Reply With Quote
Old 14-03-11, 06:51 PM   #3
Dave20046
Dave20046's Avatar
lazy mans way lol
Lazy bast!
personally I'd just bleed em...specially if it's not been done in a while.
you need some quite long thin circlip pliers (i had to grind mine down) but otherwise it's pretty straight forward.
just remove the lever and the rubber boot, take out the circlip and it all pulls out. remembering how it went , swap your pieces.
Old 14-03-11, 07:01 PM   #4
Dicky Ticker
Default Re: Curvy front master cylinder service?
If the master cylinder is in need of a service it may be reasonable to assume the brake fluid needs changing so pump plenty through when you bleed them
Old 14-03-11, 07:10 PM   #5
Nicky S
Nicky S's Avatar
Lazy bast!
lol
thats them circlips
+1
Old 14-03-11, 07:10 PM   #6
daveyrach
lazy mans way lol
I am servicing because he rubber boot is all broken up and brittle and secondly under heavy braking the the piston kind of judders in and out not very smooth. I have some circlip plier like the attached pic, will these do?Attachment 8666
Old 14-03-11, 07:35 PM   #7
Nicky S
Nicky S's Avatar
yer they will work fine.
this is what you will be changing
are you sure its not the pistons or the piston seals that need changing ?
Old 14-03-11, 07:40 PM   #8
daveyrach
Yes this is wat I have, how do I kno its the seals and are they not in this kit?
Old 15-03-11, 09:34 AM   #9
Nicky S
Nicky S's Avatar
This kit is only for the master cyclinder. But there is also another kit for the master cyclinder that is the lid and seal.
Ahhhh i think iv confused you i ment the seals in the cailpers that hold the pistons in
Old 15-03-11, 09:39 AM   #10
daveyrach
I'm not sure about the caliper i will check tho, the main issue is the pistion in the actual master cylinder beinng stiff and doesn't moce smoothly so i will satrt there.
Front master cylinder sniff Stuff Wanted 3 28-04-10 09:19 AM
Front Brake Hoses and Master Cylinder - Curvy Big Daft Lad Stuff Wanted 1 13-02-09 12:37 PM
Pointy or Curvy, 650 or 1000 Naked SV Front Master Cylinder SoulKiss Stuff Wanted 0 19-03-08 06:30 PM
Front master cylinder taggy Stuff Wanted 7 31-08-07 06:02 PM
R1/R6 Front master Cylinder jonnygman SV Talk, Tuning & Tweaking 6 29-04-07 01:10 PM
