Old 16-03-11, 10:50 AM   #1
carlosjonez
Default Trouble Fitting lower fairings (curvy)
Hi all, i recently bought a set of used lower fairings for my curvy. they are definitely the correct type but I tried locating the n/s fairing the other day and none of the holes matched anywhere on the frame.
It has never had lower fairings fitted before. Do i need a set of brackets or something?
Thanks
Old 16-03-11, 10:54 AM   #2
Dicky Ticker
Default Re: Trouble Fitting lower fairings (curvy)
Possibly --yes They don't fix directly to the bike
Old 16-03-11, 11:15 AM   #3
dyzio
dyzio's Avatar
Thanks
Yes you do. Can't find them online at the moment, maybe someone else will.
Old 16-03-11, 11:28 AM   #4
carlosjonez
Aah brilliant thanks! Thought I was going mad! If anyone can point me in the right direction i would be most grateful.
Thanks
Old 16-03-11, 01:13 PM   #5
carlosjonez
I've just found the correct fitting kit for my bike. There are a lot of bits and brackets!
Here is the link if anyone has the same question:
http://www.robinsonsfoundry.co.uk/bu...73-430-010.htm
Old 16-03-11, 01:17 PM   #6
dyzio
dyzio's Avatar
That's the one.
If your bike suffers from the wet front plug syndrome, make sure you clean the drain hole, grease the cap before fitting it, pain in the Rse otherwise.
Old 16-03-11, 03:53 PM   #7
carlosjonez
Hi,i'm not familiar with the wet plug syndrome. I take it that's when you're riding in all weathers and this is a good precautionary measure?
Old 16-03-11, 04:01 PM   #8
dyzio
dyzio's Avatar
Some SV's don't like riding in the wet, some more than others - mine didn't even like being parked outside :/
The problem is water from the front wheel gets on the front cylinder spark plug cap and can cause the front cylinder to missfire or stop working.
Look here: http://forums.sv650.org/showthread.php?t=81046 and http://forums.sv650.org/showpost.php...69&postcount=6
Reason I mention it is because it's easier to do now, than once you have the fairing on and the bracket on the radiator.
Old 16-03-11, 04:04 PM   #9
carlosjonez
Brilliant thanks for the advice. Any particular grease you recommend?
Old 16-03-11, 04:05 PM   #10
carlosjonez
Aah sorted thanks. Found it on the other thread
Fitting 99-02 oem lower fairings Makalux SV Talk, Tuning & Tweaking 14 05-03-16 08:23 PM
Fitting lower fairings to curvy degsy SV Talk, Tuning & Tweaking 6 19-05-10 09:51 PM
Lower fairings fitting kit joshua02 SV Talk, Tuning & Tweaking 3 06-05-10 01:20 PM
K4 Lower Fairings Fitting Kit booner Stuff Wanted 0 27-07-07 03:31 PM
Fitting lower fairings bikerskez SV Talk, Tuning & Tweaking 8 24-12-04 10:51 PM
