Old 23-03-11, 10:34 PM   #1
GixxerMatt
Default Do rear sets make a real difference?
Now my problemo is im lanky and my bike is small lol
Do rear sets actually make any diffrence as you can only really move the position a couple on inches ?? or will it make a big diffrence.
basically i just want a bit more comfort, as much as possible on a sportsbike
Old 23-03-11, 10:36 PM   #2
davepreston
Default Re: Rear sets
yes it helps, from a 6 foot 8 orger
hth
Old 23-03-11, 10:42 PM   #3
My rearsets are higher than the standard pegs at their lowest setting
so I guess it depends what make you get
Old 23-03-11, 10:45 PM   #4
GixxerMatt
oww i never thought of that actually lol. ill just hope they go lower than standard
Old 24-03-11, 09:20 AM   #5
Stig
Default Re: Do rear sets make a real difference?
I always thought aftermarket rearsets moved the pegs higher and further back. The opposite of what a person of considerable more length than me would need.
Old 24-03-11, 10:23 AM   #6
SVMAT
If they have adjuster plates you can just switch them from one rearset to the other so they adjust downwards rather than upwards...in other words so the adjuster plates are wrong way up on wrong side. You may have ground clearance issues if you ride hard though and may have to factor in a jack up kit or longer shock from a gsxr or sumin...
Old 24-03-11, 10:48 AM   #7
rictus01
rictus01's Avatar
rearsets are designed traditionally for a higher footpeg position, but as said some can be manipulated to go down and back, but this isn't the best solution if comfort is your goal for two main reasons, firstly the cost, the most adjustable rearsets are generally the most expensive, and secondly they remove the rubber footpeg itself and you end up with a fixed metal one, which transmits more vibration.
If all you want is a more relaxed position then either drop plates or something like this would do a better and cheaper job; retaining the original footpeg in the process.
Cheers Mark.
Old 24-03-11, 07:13 PM   #8
GixxerMatt
Cheers Mark.
thanks they look perfect for my needs really
regards Matt
Old 25-03-11, 06:56 PM   #9
kerby
what about a thicker seat?I have added 30mm to the front of mine and got the original cover back on ,it helped a good bit.
Old 25-03-11, 07:23 PM   #10
Cheers Mark.
What Rictus has suggested is a good idea. However I tried some on my SV and I didn't get on with them. They moved my foot position further out on both sides, so the gear change didn't sit naturally in relation to the boot and neither did the rear brake pedal. I had to make a concious effort to think about where my foot was in relation to the foot controls.
Can I suggest an alternative, which is the way i went. You can get riser plates for most sports bikes, including Gixxers. But instead of using them as risers, use them upside down to give you more leg room. Foot pegs and foot controls stay in the same plane.
There's various holes where to bolt the pegs to.
Might need to file them a wee bit to fit upside down, but IMHO these are safer than the other option. But thats just my opinion
Do a search on Ebay for riser plates and it'll throw up a few choices
Cans - what difference do they make? bampy SV Talk, Tuning & Tweaking 31 26-03-09 01:48 PM
Will it make a difference tho? Spiderman Soho Massive 12 26-07-08 01:05 PM
33bhp - Does this make a lot of difference? jans1971 Bikes - Talk & Issues 121 12-12-07 11:07 AM
Chain & Sprockets - will 46t rear make any difference? FreshAL SV Talk, Tuning & Tweaking 5 17-07-07 05:06 PM
The difference a few miles make Viney Bikes - Talk & Issues 12 05-06-06 04:17 PM
