Racing and Paddock Chat The latest news, talk, and gossip from the world of bike racing, you can also discuss track days here too.
Old 25-03-11, 04:44 PM   #1
prilpot
Default suspension advice needed
recently brought a sv 650 race bike.came with a invoice for fork springs emulators and something else
taken apart and 2 codes on spring
270029 and 95
does the 95 mean 9.5 the weight
find these soft anyone know if i can go harder
plus what weight oil and what air gap
i weigh 13 .1/2 stone with kit on
any help would be grate cheers
Old 25-03-11, 05:08 PM   #2
Berlin
Default Re: suspension advice needed
I'm surprised you find these soft. I race on .95's and I'm near enough 20 stone in my leathers!.
Are you sure it's not down to compression damping? When you say soft, do you mean they dive on the brakes?
The spring weight is designed to give you the correct preload/sag. What are your sag settings?
You should be running 0.90 springs for your weight on the track and either 15 weight or 20 weight oil (cold and warm weather respectively)
C
Old 25-03-11, 05:39 PM   #3
At 13 1/2 stone I would go .9 or more, would think ,95 to be about "correct" actually.
I agree with the point about compression damping, you could also avoid bottoming with more oil.
Old 25-03-11, 05:49 PM   #4
Berlin
where the hell did that come from. I'm sure I typed .90. Now edited.
according to the Racetec Spring calculator you can go with either .90 or.95 depending on how much you weigh out of your leathers.
C
Old 25-03-11, 07:33 PM   #5
prilpot
C
cheers for that
yeh seem to dive alot and bottom out mate of mine is doing them
do you know about the air gap aswell cheers
Old 21-04-11, 08:39 AM   #6
coxxy
Set the air gap around 110mm and see what the forks dive to under heavy braking. if you have less than 1cm of travel left on your nylon cable tie (arround the fork stanchion) you could add 15ml of fork oil = 10mm fork oil level. If they feel too stiff take out 15ml.
Suspension advice - again! ChrisCTK SV Talk, Tuning & Tweaking 1 28-01-11 07:34 PM
needed-master of the dark arts (suspension) davepreston Bikes - Talk & Issues 17 13-04-10 05:20 PM
Suspension guru needed. SUPERSTARDJ01 Bikes - Talk & Issues 2 25-03-10 04:36 PM
Help needed regards rear suspension... Adam79 The Madlanders 1 07-09-09 07:46 AM
Suspension washer needed Jay12329 Stuff Wanted 1 27-07-09 08:06 PM
