Old 27-03-11, 04:11 PM   #1
Mykey.M
Default Jack up kit dimensions?
anybody know the length of the standerd jack up plates?
im a bit to tall for my sv and want to jack it up but i need to no what the standered ones are and see how much to go up
anyone have the answers
Old 27-03-11, 05:05 PM   #2
Owenski
Default Re: Jack up kits.
if you browse on ebay for SV dog bones you'll find items listed as "adds 25mm seat height", "adds 50mm seat height" etc but its been mentioned here before, there are other ways to improve the riding position for taller riders which wont mess up the geometry of the bike. Consider aftermarket adjustable rear sets and a comfort kit with bar risers and so on. That seems to be the way to do it or at least it has better general approval compeared to swapping out the dog bones.
Old 27-03-11, 05:15 PM   #3
21QUEST
21QUEST's Avatar
A jack up kit(dogbones) won't help with your 'problem'... distance from pegs to sit would still be the same
Nemo me impune lacessit.
Old 27-03-11, 07:53 PM   #4
paulzsv
Hi mykey, ive got some newish dog bones that are too high for me, these are 145mm hole centre to centre which lift the back quite high. I believe the standard ones are about 110mm. i'm looking for some in the range of about 120mm ish if thats any help.
Old 27-03-11, 08:11 PM   #5
sprocket
I made some custom ones a while ago . . but cant remember the size now I think around the 145mm range. I'm 6'2" and this feels like a good height for me. I also dropped the front end to give the bike a more aggressive cornering style
Old 27-03-11, 09:06 PM   #6
bigchris
I made my own.
The hole centre dimension was 95mm which jacked the back end up 47mm.
On a curvy the shorter the bones the higher the back end.
I think it's the opposite on a pointy but I'm not 100%.
I think the standard curvy bones are 108mm hole centre to hole centre.
Hope this helps, you didn't say if you have a superior curvy or a pointy??
Old 27-03-11, 09:22 PM   #7
Electro
Its a curvy Chris, in his sig.
Old 27-03-11, 10:03 PM   #8
bigchris
Ahh, couldn't see for looking!!! :-0
Old 29-03-11, 05:39 PM   #9
Mykey.M
im 6'2 aswell. ive been told to drop the front end to help but i want the bike to feel bigger when im on it.
how much did you drop the front end by?
and is that 145mm from hole to hole on the jack up plates?
Old 29-03-11, 09:05 PM   #10
sprocket
Default Re: Jack up kit dimensions?
Hey mykey, I'm not 100% sure what I used now, I'll see what I an find out for you, mine does feel a lot more comfortable now and she corners better. Only problem with jacking up the rear end is its difficult to fit a different shock. I have a zx10 thatwont fit, but I.ll check the dimensions for you.
GSXR750 dimensions? Stuuk1 Bikes - Talk & Issues 10 23-02-11 07:41 AM
SV Dimensions danf1234 SV Talk, Tuning & Tweaking 25 27-11-10 07:09 PM
Jack-up kit dimensions. Wideboy SV Talk, Tuning & Tweaking 18 18-06-10 09:45 AM
Wheel dimensions. gixerboy1 SV Talk, Tuning & Tweaking 5 29-12-06 07:55 PM
SV650 dimensions.. SteveB SV Talk, Tuning & Tweaking 10 26-04-06 10:10 AM
