I know I know this has been done to death, ressurected and zombified many times.
I'm after some specific advice for getting an old 400 back to life. I'm doing this for friend some point next week and really need an 'idiots' list of what to check/ clean/ t**t with a hammer ![]() The bike hasn't turned over properly since 2008 (we think!) and was running like a bike of s*** then. What the things that need checked/ replaced to get it going again? Thanks in advance and over to you
It may help to know what it is?
![]() I had a Bindit400 laid up for years after the missus went "roaming in the gloamin" with it. Apart from crash damage, changed the blued tyres and stripped and cleaned carbs, new diaphrams and jets so it would be back to running like a dog...just like standard! New battery, dumped old fuel. That was enough to get it screamin again. Be lucky. ![]() |
D'oh its a GSXR 400 GK73
This has just sat there unloved thankfully
Sparks and fuel is a good place to start,then battery--get the engine running and do the other bits after
It some times helps to turn the engine over a couple of times while the plugs are removed to get a bit of oil round the engine before you fire it up. |
id change the fuel or at least slosh it around to try and move some of the carp that might have settled near the fuel tap.
spark plugs/oil/check air filter for illegal immigrants and if your trying to start it, try and start it outside the shed/garage. i made this mistake with my old DT125MX, 2 stroke smoke gets very thick and chokes rather easily haha |
Carb 'O' rings on the 400 are meant to cause running problems
Black naked 1999 sv650 which im trying to keep happy Custom paintwork Saragon Customs Spray painting Electrical fault finding guide and Regulator rectifier test Only a biker knows why a dog sticks his head out of a car window. |
thanks all!
Nothing untoward beyond what I was expecting I'll rod the jets as a temp measure as I'm trying to do this on the cheep fo a friend
Massive Apology, Massive Thank You, from THE C0CK | Scoobs | Idle Banter | 37 | 18-10-10 04:04 PM |
A massive thank you to the org. | Seggons | Idle Banter | 20 | 18-08-10 06:29 PM |
New massive anthem!!!!!!!!! | carnivore | Pennine Massive | 9 | 17-05-10 05:52 PM |
New bike video from the Pennine Massive Rideout 19th Jan | Paul the 6th | Bikes - Talk & Issues | 30 | 21-01-08 08:29 PM |
Where have the massive gone | Smudge | Pennine Massive | 71 | 23-10-07 06:53 PM |
