Old 04-04-11, 04:54 PM   #1
Orpheus
Default I can no longer get the horn.
I was queueing behind a lady today, whom remained stationary after it was her turn to go, so i thought i'd alert her with my horn. To my utter horror and embarrassment, i could not produce a horn. I had to resort to simply flashing at her instead.
Upon closer inspection at home it appears i can produce a very little horn, but nothing that anybody would notice. I feel wholly inadequate.
Is there a common cause for this? What can i do to rectify this? Any help in getting back my thunderous horn will be greatly appreciated.
Old 04-04-11, 05:01 PM   #2
emcf
Default Re: I can no longer get the horn.
the OE horn sounds daft but should make a decent noise. perhaps you've got a poor/corroded connection that needs looked at. are all the other electrics working fine?
i binned the OE horn and stuck a car horn on it instead, much louder. some folks stick two horns on with a relay, i think TSM has done some posts on how to do this.
Old 04-04-11, 05:15 PM   #3
ImplodedHamster
mine does this sometimes :/
will any car horn do? and can it just be wired in or would you need a different relay?
Old 04-04-11, 05:21 PM   #4
danf1234
What is an easy replacement for the rather sh1te standard horn, without fitting a fog horn thing?
Old 04-04-11, 05:40 PM   #5
-Ralph-
Your horn is located too close to your hot parts, it gets hot too, and when that happens it stops functioning properly. You need to perform a little operation to move your horn further away from your hot parts, or you need to have your horn replaced altogether with an upgraded model. It's a very common fault within your gene pool.
Old 04-04-11, 05:58 PM   #6
you can your horn back by cleaning the bits that give it some life. I recommend removing the contacts out of its shrouding* and giving it a gentle buff with a scotchbrite.....and it'll spring back to life!
*I'm going on the thinking its the same as the curvy one and has a spade connector sat in a plastic thing, somewhere inbetween the front forks.
Old 04-04-11, 06:09 PM   #7
flymo
flymo's Avatar
ha ha, did your computer fall into the wrong hands?
Old 04-04-11, 06:10 PM   #8
you can your horn back by rubbing the dirty bits that give it life. I recommend removing the contacts out of its shrouding* and giving it a gentle buff with a scotchbrite.....and it'll spring back to life!
If you've lost the Horn, get a replacement treated with Viagra
Its called a Stebel Nautilus compact, they'll really know when you've got the horn then
Old 04-04-11, 06:31 PM   #9
my horns always worked
Old 04-04-11, 06:37 PM   #10
Teejayexc
Well, I've found quite the opposite, 'tis a bugger to get my horn to work when it's cold, and it must be an optical illusion, but it appears to get smaller too *
*though I've heard this is more to do with the aspect, I'll try one of those fancy mirrors next time
For those with a longer leg gettin2dizzy Suits 19 19-03-09 06:33 PM
Off the road a bit longer. Sean_C East Anglian Revolution 8 27-10-08 07:25 PM
I couldn't do it any longer. DanAbnormal Guildford Massive 25 30-04-07 01:46 PM
No longer for sale Saint Matt For Sale - SV's and SV related items 1 18-12-05 09:58 AM
No longer an SV owner..... tonyt SV Talk, Tuning & Tweaking 6 02-01-70 02:27 PM
