Old 04-04-11, 05:08 PM   #1
muzikill
muzikill's Avatar
Default Haynes corrections?
Always wondered why they dont post corrections on their website?
anyhoo, does anyone know wether its worth buying the new version on the sv650 haynes manual? - has anyone done a comparison to see if it has 'updates' to wrong info in the previous version?
Haynes Manual stevie16v For Sale - SV's and SV related items 2 09-09-09 06:35 PM
Haynes manual Kuze SV Talk, Tuning & Tweaking 1 05-08-09 11:14 AM
Anyone need a haynes for a curvey? Jase22 Pennine Massive 1 05-11-08 11:02 AM
haynes manual ginge For Sale - SV's and SV related items 3 06-06-07 11:30 AM
Haynes Robbo_ SV Talk, Tuning & Tweaking 34 18-03-06 08:46 PM
