Old 10-04-11, 10:36 PM   #1
T0mmyGun92
Default k6 to k9 engine swap?
right... atm i have an 07 plate sv but k6 set up... end of k6 line bike getting registered late. done about 30k mile, i'm the third owner and the engine has gone bang. So i'm looking at buying a crashed and cosmetically damaged sv, found a few online. Best I have found so far is a k9 sv with rh plastic damage, engine n forks etc. fine n 2500 miles on the clock at a good price so got me interested, only problem that i have thought of is that the k6 engines had the single spark plug per cylinder, and k7 onwards had 2 per cylinder. Does this mean that the engines wouldn't be able to be swapped or would it be a simple task of just swapping the plug wiring from the k9 model to my k6?
Old 11-04-11, 08:42 AM   #2
jambo
jambo's Avatar
Default Re: k6 to k9 engine swap?
I've not done this. However, the motors are going to be physically identical in terms of fitting into the frame.
Your headaches will be to do with electrics. I believe the K9 has duel spark heads as you've pointed out so you might need the coils from the K9. They also have a sensor in the exhaust which I'm not sure the K6 had so you'll either need to move all the electrics across from the K9, and the extra sensors or move only what you need to run the extra plugs. I doubt it's going to be too hard though.
Jambo
Old 11-04-11, 10:12 AM   #3
Stonesie
I would transplant everything engine related because they have a lambda sensor in the exhaust, different ECU and that means a different engine wiring loom.
Old 12-04-11, 06:36 PM   #4
T0mmyGun92
yeah spoke to the mechanic and he said the same as stonesie, found a couple of crashed and cosmetically damaged ones so think i may have to buy that and take the parts off of mine and put it onto that
Engine Swap lazymanc SV Talk, Tuning & Tweaking 18 25-04-11 11:15 AM
sv650 engine swap k6 to k8 Pix SV Talk, Tuning & Tweaking 1 16-05-10 07:49 AM
SV650S engine swap LeeSV SV Talk, Tuning & Tweaking 7 26-02-07 08:33 PM
Swap Old Engine into Newer SV? wmrra#30 SV Talk, Tuning & Tweaking 5 21-09-06 11:10 AM
sv650 engine swap toyotafj40s SV Talk, Tuning & Tweaking 5 24-08-06 08:54 PM
