Old 12-04-11, 07:59 PM   #1
muzikill
muzikill's Avatar
Default Pair reed valves - are they OK?
As part of the rebuild i'm just checking to see if these look ok to you lot in the know.
An evening with Paul Reed Smith guitar luthier extraordinaire! 4fold Idle Banter 9 12-03-11 11:48 PM
valves - am i doing it right? Wideboy Bikes - Talk & Issues 9 18-10-08 03:33 PM
valves Wideboy Bikes - Talk & Issues 19 12-10-08 11:56 AM
LED tyre valves Kinvig SV Talk, Tuning & Tweaking 17 18-12-06 09:32 PM
valves sv650s_guy SV Talk, Tuning & Tweaking 6 10-03-06 10:25 PM
