Old 14-04-11, 10:07 AM   #1
Nick_69
Nick_69's Avatar
Default Radial brake master cylinder for GSXR front end?
Im doing a gsxr front on swap on my sv650 k9 and i need to get a radial brake master cylinder, i was just wondering do i have to use a gsxr master cylinder or could i use another one.
It will be for a k7 600 front end
cheer nick
Was SV650S K9
Now GSXR 600 K9
Old 14-04-11, 10:12 AM   #2
SVMAT
Default Re: Radial brake master cylinder
I think you can use the sv one but im not 100%. I know on gsxrs people change to brembo or r1 master cyclinders for better feel or less travel lever end. hth
Old 14-04-11, 01:34 PM   #3
Default Re: Radial brake master cylinder for GSXR front end?
dont fret about a radial M/C just use the SV one.
Old 14-04-11, 04:06 PM   #4
Nick_69
Nick_69's Avatar
does it not make much difference then
Was SV650S K9
Now GSXR 600 K9
Old 14-04-11, 04:51 PM   #5
The sv's m/c is more than enough. I've got it on mine with gsxr calipers
Old 14-04-11, 05:00 PM   #6
Nick_69
Nick_69's Avatar
Cool. Cheers for the advice all i need now is a gsxr 600 k6 or 7 wheel now
Was SV650S K9
Now GSXR 600 K9
Old 14-04-11, 05:41 PM   #7
Master cyl does not know or care which direction caliper mounting bolts are pointing.
SV one works fine.
Old 14-04-11, 06:32 PM   #8
+2 here, more than enough DF for me nissin calipers
Old 15-04-11, 12:41 AM   #9
Lozzo
It may not be needed as such, but the feel and adjustability of a radial type m/cyl is desirable. There may also be issues with the ratio of the lever in relation to the bore of the m/cyl and whether it will flow enough fluid to make the newly fitted radial calipers function at their best. I've found that scrapping the crap stock Nissin m/cyl on many Suzukis and Kawasaki fitted with Tokico calipers makes a big change for the better. You get a more positive lever and the effectiveness of the brakes is increased substantially as you have much better feel and control over what the stock m/cyl gives.
GSXR 750 k6/k7 radial master cylinder & lever £50 sv650k4 For Sale - Other Bikes and General biking items 2 06-09-09 08:31 PM
Suzuki GSXR K5 600 Radial Master Cylinder + Lever Ter For Sale - Other Bikes and General biking items 18 17-04-09 10:07 PM
GSXR Radial front brake master cylinder DanF For Sale - SV's and SV related items 8 16-03-08 11:24 PM
Brake parts- EBC pads, GSXR radial master cylinder northwind For Sale - SV's and SV related items 10 03-09-07 07:33 PM
Swap GSXR forks/radial brakes/radial master cylinder/wheel Teknic SV Talk, Tuning & Tweaking 2 16-03-05 07:19 AM
