Old 17-04-11, 06:38 PM   #1
HoL
Default Crunchy sticking gears
Hi all, I desperately need a bit of help. I've got a naked K2 which the gears are being really temperamental, sometimes I can flick through them nice & smoothly other times it just won't change - quite often after starting off it gets stuck in first but if I slow right down or stop it'll let me change.
From reading other threads so far I've tried:
Cleaning behind the sprocket cover
Fresh oil - which I then drained some so it's just over min mark cos it was still happening.
I was told today it was because the chain was dry so that's now lubed but the same guy who told me this said it would probably take a week to rectify itself.
Obviously I've got my fingers crossed to see if it works but I'm new to this & can't see how the chain could affect the gears?
So just after some opinions, could it be due to the chain? any other ideas? a little terrified of a big bill problem!
Old 17-04-11, 07:55 PM   #2
Default Re: Crunchy sticking gears
I'd try properly adjusting the chain, as it sounds like a overly loose chain
Old 17-04-11, 08:17 PM   #3
HoL
I was told it was ok but theres a couple of guys in work with bikes so I'll see what they think
Old 17-04-11, 08:23 PM   #4
the chain should have between 20 and 30mm of play/ slack on the main stand (in the SV's case the side stand)
Old 17-04-11, 08:31 PM   #5
HoL
(thanks by the way)
Old 17-04-11, 08:32 PM   #6
HoL
Whoah, yeah I think it's way off! Probably double that. Ta
Gears of War 2 plowsie Idle Banter 12 19-08-09 10:32 PM
no gears. Bibio SV Talk, Tuning & Tweaking 11 19-10-08 01:27 PM
teh "what u doing at weekend" fred. sponsored by kellogs crunchy nut cornflakes. they're nuttier than squirrel poo keithd Idle Banter 43 28-04-08 10:05 AM
Gears Taylor1975 SV Talk, Tuning & Tweaking 1 29-03-08 01:23 PM
Gears sticking after hard braking Yarodia SV Talk, Tuning & Tweaking 11 03-07-06 04:38 AM
