Old 19-04-11, 05:43 PM   #1
dazzaboy
Default Is choke not fully off?
hi hoping someone can help, i have a 2001 curvy and noticed that when going along about 20mph its abit jerky. This has only started recently. not sure if choke is'nt fully off or it needs abit of tuning with?
Old 19-04-11, 06:17 PM   #2
Default Re: Is choke not fully off?
Couple of possible problems, choke is one of them. Throttle valves being out of balance wouldn't help either.
Old 19-04-11, 06:32 PM   #3
dazzaboy
is there a way of letting off the choke cable abit?
Old 19-04-11, 06:46 PM   #4
Not like that, plungers seize/stick in carbs. Take them out, clean and lube.
Old 19-04-11, 06:48 PM   #5
http://www.youtube.com/watch?v=uc7uyMs-YtQ
Old 19-04-11, 06:53 PM   #6
dazzaboy
i had all them out not that long ago and i greased them all then. As soon as i touch the choke the revs pick up and i thought there should be some free play
Old 19-04-11, 06:54 PM   #7
Yeah, maybe you don't have cable seated right in splitter?
If everything is seated right then there is a bit of adjustment in the cable, just under the lever, hexagonal bit.
Old 19-04-11, 06:58 PM   #8
dazzaboy
ok i'll have a look tommorrow, i do need them carbs balanced aswell so that will hopefully help. Thanks for your help.
Where can i get new choke plungers? achapman01 SV Talk, Tuning & Tweaking 3 05-08-10 09:09 PM
New choke cable ricky_t SV Talk, Tuning & Tweaking 2 14-04-10 09:00 PM
Sticky choke :( dyzio Bikes - Talk & Issues 3 31-03-08 03:22 PM
New Choke Cable Anyone? Magoo Soho Massive 0 06-03-07 09:35 AM
Sticky Choke fizzwheel SV Talk, Tuning & Tweaking 6 19-07-05 10:24 AM
