Old 21-04-11, 07:46 AM   #1
daveyrach
Default Car Horn on SV?
Would a Halfords car horn be plug and play on the SV?
Old 21-04-11, 07:58 AM   #2
Default Re: Car Horn on SV
Most folk use a relay to protect the wiring. But yes most horns are plug and play.
I've fitted a stebel nautillus compact to mine, but requires splitting the horn from the compressor, which isn't as difficult as it sounds.
Googlefu it, or look on SvRider.com on how to do this
Old 21-04-11, 08:03 AM   #3
daveyrach
How do you add the relay, and what sort would i need, could i pick it up from halfords?
Old 21-04-11, 08:09 AM   #4
warmshed
Worth looking at the Stebel Magnum, they are a bit smaller and just as loud. Sounds like a Lorry!
Old 21-04-11, 08:14 AM   #5
Remove horn terminals and connect to relay (see relay instructions). make up a wire and connect one end to positive battery terminal, the other end to the correct terminal on the relay, another from the - terminal on the battery to the negative on the horn, but just as easy to find a place on the frame to earth it to.
Then from the relay make up two wires to the horn connection, one + & one -
Secure relay somewhere, I hid mine under the tank
Thats how I did mine, others may have an easier solution
The horn button on the LH switchgear activates the relay and allows power to go to the horn, but protects the Sv wiring
Yes, you can get everything you need at Halfrauds, my Stebel came with a relay.
Sounds difficult, but it isn't
Old 21-04-11, 08:14 AM   #6
daveyrach
I only want a cheap replacement, with regard to the relay i take it i will need a 4 pin 12v replay but what amparage?
My horn had given up completely and i'm broke so need to do it cheaply
Old 21-04-11, 08:18 AM   #7
daveyrach
Remove horn terminals and plug into relay. make up a wire and connect one end to positive battery terminal, the other end to the correct terminal on the relay, another from the - terminal on the battery to the negative on the horn, but just as easy to find a place on the frame to earth it to.
So if just a std 12v car horn i'd need a five pin relay going by how many connections you'e mentioned?
Seems easy enough, wat Amps tho dnt wanna get the wrong relay
Old 21-04-11, 08:22 AM   #8
Pass, I just used the relay that came with the horn, might have been 20amps, but I might be wrong
Old 21-04-11, 08:24 AM   #9
daveyrach
How many pins?
Old 21-04-11, 08:28 AM   #10
4 if I remember correctly
No Horn pin64 SV Talk, Tuning & Tweaking 1 19-07-09 12:11 PM
The horn Kinvig Stuff Wanted 6 18-08-08 12:15 PM
Got the Horn? metalmonkey Idle Banter 0 24-10-07 04:57 PM
Are you getting the Horn? DanDare Bikes - Talk & Issues 3 06-07-06 12:56 PM
Get the horn northwind SV Talk, Tuning & Tweaking 44 02-03-05 12:22 AM
