Old 28-04-11, 08:34 PM   #1
jimmyb96
Default noise after fitting asv clucth lever
Hi Guys,
I fitted a set of asv shorty levers to day and on clutch side when i engage gear and let clutch out, at almost the very end of releasing the lever a clicky noise starts coming from down round gear change lever and if i pull clutch in again it goes away as wheel slows down and stops.
I have not taken it for a ride its still on paddock stand
Bike is sv650s k7 2007, 7000miles
Any help greatly appreciated.
Old 29-04-11, 04:40 PM   #2
NedSVS
Default Re: noise after fitting asv clucth lever
I'm guessing its got nothing to do with your lever change. Rotate your back wheel by hand, whilst in neutral & engine not running, and listen for the noise. Possibly a tight spot in your chain?
RH Footpeg Hanger, Rear Brake Lever and Clutch Lever for 2004 Naked Wanted Drumming_Animal Stuff Wanted 0 26-07-10 10:52 PM
Clutch lever removal/fitting Kinvig SV Talk, Tuning & Tweaking 4 03-11-07 05:16 PM
K5 Pointy 650S right hand wing mirror, gear lever and clutch lever. Bayside GTR Stuff Wanted 0 29-10-07 11:24 PM
Clicking noise after fitting new exhaust tomjones2 Bikes - Talk & Issues 2 04-06-07 02:40 PM
Screeching noise? what noise does your SV make? branny SV Talk, Tuning & Tweaking 5 30-06-06 12:09 PM
