Old 29-04-11, 10:48 AM   #1
Nobbylad
Nobbylad's Avatar
Default Oil in air filter - is this much 'normal'?
Admittedly, this one has been in a while, however would you expect this much build up of oil in the air filter?
I appreciate there's always going to be some oil misting up into the airbox, however would you expect this much after around 12k miles?
Old 29-04-11, 10:51 AM   #2
tom-k6
Default Re: Oil in air filter - is this much 'normal'?
mine had a smaller amount in there at about the same miles, but i always forgot to keep oil topped up, i thiink as long as its not pooling, but there is a small drain pipe so should be a massive thing
Old 29-04-11, 12:34 PM   #3
xXBADGERXx
I wouldn`t worry too much about it mate , I removed one that had done 7k on it and it was similar to that , I put it down to the dealer over-filling the gearbox . Every filter I changed after that had a small witness mark on it and it has never repeated , my engine has done of 55k now and still going strong .
Spark Plugs, oil filter, Air Filter....Curvy 21QUEST For Sale - SV's and SV related items 2 14-01-10 10:04 PM
Is the .org normal? captainsmelly Idle Banter 58 21-07-09 12:26 PM
is this normal spakmitten SV Talk, Tuning & Tweaking 2 27-07-05 05:28 PM
is this normal ? mark SV Talk, Tuning & Tweaking 6 08-02-05 02:11 AM
To filter or not to Filter.....are you feeling lucky? Magoo Bikes - Talk & Issues 40 02-12-04 05:17 PM
