Old 30-04-11, 10:41 AM   #1
jimathyy
Default where do these pipes go?
I have 2 pipes coming off the water system that are not seeming to go anywhere at the pivot end of the fuel tank. There is one long pipe, connected to a T with a long pipe and a shorter thicker pipe coming off them Any ideas where they route to?
Old 30-04-11, 12:01 PM   #2
flymo
flymo's Avatar
Default Re: where do these pipes go?
very likely the overflow, are they the thin black tubes that exit below the footpeg area?
Old 30-04-11, 04:48 PM   #3
jimathyy
the thin one could do, but it's sat by the tank at the mo as i've been looking for somewhere to plug it in. I thought of this, but can't work out where the thicker pipe should go to to correlate with this theory.
Old 30-04-11, 05:28 PM   #4
zadar
Short one plugs in fuel tank and long one goes down by engine and just hangs between engine and frame.
Old 30-04-11, 05:58 PM   #5
jimathyy
yeah? Why would water be going into the fuel tank? I can see where it would go, just seems weird....
Old 30-04-11, 06:35 PM   #6
flymo
flymo's Avatar
water drain
Old 01-05-11, 12:44 AM   #7
zadar
Water will flow down, not up.
Old 01-05-11, 01:24 AM   #8
a1istair
Does the other long pipe go to the coolant overflow?
Old 01-05-11, 01:54 AM   #9
zadar
It comes from overflow bottle and than splits two way with T fitting, short end goes to tank and longer goes down and just sits there open. Either water or fuel will flow down on the floor if any comes out of overflow or tank.
Old 01-05-11, 05:33 AM   #10
jimathyy
cheers guys!
Air box and pipes Mishelly212 SV Talk, Tuning & Tweaking 1 28-05-10 05:11 PM
M4 pipes. yorkie_chris Exhausts 4 04-07-09 06:45 PM
Look at them pipes then........ rictus01 Photos 19 25-01-09 08:26 PM
New Pipes for my VFR Luckypants Bikes - Talk & Issues 66 03-03-08 04:08 PM
pipes didge Exhausts 19 02-07-05 05:33 PM
