Old 03-05-11, 08:57 PM   #1
v0r73x
Junior Member
Default SK7 Gear Lever
Hi All,
First time posting here, first SV, first bike drop So gutted!
Fortunately no real damage just snapped the gear lever sticky outty bit. The lever itself is fine but I've been searching all evening and by the looks of it the whole lever assembly needs swapping instead of some sort of bolt/rubber cover if I want an OEM replacement?
Part number appears to be 25600-17G00??
Any help appreciated or suggestions on where/what to get. Thanks in advance!
v0r73x is offline   Reply With Quote
Old 03-05-11, 10:24 PM   #2
MisterTommyH
MisterTommyH's Avatar
Default Re: SK7 Gear Lever
www.fixer-peg.co.uk
MisterTommyH is offline   Reply With Quote
Old 04-05-11, 05:53 AM   #3
v0r73x
Junior Member
Ah awesome, thanks for the link. I take it these aren't too hard wearing on your boots over a rubber replacement?
Old 04-05-11, 06:43 AM   #4
MisterTommyH
I've never used one so I wouldn't know. The guy who sells them is an Orger so if you search the forum for fixer peg you should be able to get some more info.
Old 04-05-11, 07:30 AM   #5
v0r73x
Junior Member
Ordered Thanks again!
Curvy clutch lever and gear shift lever ibanezlynx Stuff Wanted 4 25-04-11 11:02 AM
Gear Selection Lever and Clutch Lever for K3 SV650S xXBADGERXx Stuff Wanted 7 17-01-09 02:04 PM
How to straighten a bent gear lever? (heat it up first? or what?), ---possible fix or recipe for snapped of gear lever :-) martin_SV SV Talk, Tuning & Tweaking 10 30-07-08 08:40 PM
K5 Pointy 650S right hand wing mirror, gear lever and clutch lever. Bayside GTR Stuff Wanted 0 29-10-07 11:24 PM
2 left indicators + clutch lever + gear lever for pointy k6 enduroman Stuff Wanted 3 06-09-07 09:26 PM
