Old 08-05-11, 07:18 PM   #1
little red
Default Engine ratlles
Hi All,
Can anyone help me?
Is a rattly cam / primary chain normal on a 1999 SV 650 X with 14ish K miles?
Old 08-05-11, 07:23 PM   #2
husky03
Default Re: Engine ratlles
yep-search cam chain tensioner
Old 08-05-11, 07:24 PM   #3
Dunn-y
SVs are known for their noisey Cam chains. It all depends on what sort of rattle. Does the rattle get louder as you increase revs? Does it completely disappear when you come off the throttle whilst riding?
Old 09-05-11, 07:24 AM   #4
little red
Thanks for the reply Echo.
The noise could well be camchain although a mechanic said that it isn't unknown for primary chains to make similar noises.
Is it possible to adjust this out or do "they all do that sir".
Old 09-05-11, 07:46 AM   #5
daveyrach
Most will be noisy to some extent, mine rattles on the front cylinder, nothing to worry about tho
Old 09-05-11, 09:48 AM   #6
little red
Thanks for the info husky
I guess it's nothing to worry about, just put up with it. The next job is the front brakes as the right hand calliper is lazy and getting progressively worse, pity Bandit 12 callipers don't fit, sliding callipers are rubbish.
Thanks again
Old 09-05-11, 01:08 PM   #7
Lol
Trust me the primary chain on SV never makes any noise at all
Old 09-05-11, 01:47 PM   #8
little red
It's almost certainly the camchain. If i think about it, long camchain, OHC it makes sense.
Thanks all, I'm reassured!
Engine oil change - 5 months no engine starting sv650sfan SV Talk, Tuning & Tweaking 2 04-03-11 08:10 AM
Engine cleaning b4 engine strip w.i.p muzikill Photos 2 16-01-11 06:20 PM
engine bolts for point engine pookie Stuff Wanted 6 01-10-10 01:50 PM
Engine Breaking? Hopefully not. Engine braking - is that OK? butterick99 SV Talk, Tuning & Tweaking 14 12-09-09 10:31 PM
Engine braking... any hazzards engine wise? John 675 SV Talk, Tuning & Tweaking 21 28-03-08 07:20 PM
