Old 11-05-11, 10:06 PM   #1
sv650s 04
Default FI fault
Had a problem with my 04 plate sv650s last week, when i turned the ignition to the on position no lights lit up. The bike was basically dead. After a while of checking everything the bike was back to normal but could not see what was up with it. Had the same problem today and found that the ignition relay was not working properlyj,it was sticking in the off positipn, after bridging the relay to get it started everything seemed ok. When i took the bike off the side stand and put the bike vertical the engine cut out and the engine manigment light was flashing and there was FI flashing on the dash. Is this just the relay or something else?
Old 11-05-11, 11:15 PM   #2
Bluefish
Default Re: FI fault
side stand switch?
Old 11-05-11, 11:50 PM   #3
sv650s 04
I hadnt thought about that. What should i be checking for?
c28 fault kcowgergmm SV Talk, Tuning & Tweaking 5 26-06-08 10:25 AM
Do you know what an F1 fault is? Jayneflakes SV Talk, Tuning & Tweaking 11 07-05-08 07:21 AM
one off FI fault DavieSV SV Talk, Tuning & Tweaking 24 21-02-08 11:08 PM
FI fault glang SV Talk, Tuning & Tweaking 0 19-12-07 04:49 PM
My fault? Carsick Bikes - Talk & Issues 15 14-12-04 02:30 PM
