Old 04-06-11, 09:17 PM   #1
MrMessy
Default Curvy/Pointy Rear Shock Difference?
What is the difference between a curvy shock and a early pointy shock?
MrMessy is offline   Reply With Quote
Old 04-06-11, 09:44 PM   #2
Mr Speirs
Mr Speirs's Avatar
Default Re: Curvy/Pointy Rear Shock Difference:
Spring rate of Curvy is much higher than a pointy. Apart from that not much. Pointy is a bit shorter (7mm)
Old 05-06-11, 08:56 AM   #3
MrMessy
Why did they alter spring rate for the pointy?
Old 05-06-11, 12:19 PM   #4
Default Re: Curvy/Pointy Rear Shock Difference?
Because the suspension is not the same - thus the right spring to give the correct rate at the wheel will not be the same.
Pointy shock is approx 7/8mm shorter and is not a good fit on the Curvy.
And before anyone says this can be fixed with different length 'dogbones', it's rarely a good move as that puts the linkage in a different part of the rate curve.
Difference between batteries, Pointy/Curvy? stew SV Talk, Tuning & Tweaking 3 11-04-11 01:25 PM
pointy rear shock barwel1992 For Sale - SV's and SV related items 0 19-11-10 01:12 AM
SV650 pointy rear shock aliwakeskate Stuff Wanted 4 03-05-10 02:44 PM
Pointy ohlins rear shock smaraux Stuff Wanted 2 26-08-09 05:05 PM
Pointy Rear Shock silent11 For Sale - SV's and SV related items 1 21-07-08 03:45 PM
